When I try to pastebin 2 command like this:
echo Merry && echo Christmas | pastebinit
It only pastebins the second command, and gives the first as output:
Merry
http://paste.ubuntu.com/9605648/
Now I could just do:
echo Merry Christmas | pastebinit
And that would work, but I want to run 2 separate commands, and pipe the output to pastebinit, I can't:
sudo apt-get install christmas && sudo apt-get update | pastebinit
does not seem to work.
Eric Carvalho
  • 55,453
Tim
  • 33,500
Wrap it to make a compound command:
{ echo Merry && echo Christmas;} | pastebinit
In general, to pipe the output of multiple commands in sequence to another command, do:
{ cmd1; cmd2; ...;} | cmd
or
(cmd1; ... ) | cmd
Tim
  • 33,500
muru
  • 207,228
Is there a reason you couldn't first redirect the output of the two commands into a file (using append for the output of the second command), and then pipe that to pastebinit?
echo Merry > out.txt && echo Christmas >> out.txt && cat out.txt | pastebinit
Maybe redirect stderr to the out file also.
muru
  • 207,228
Here follows a work-around to answer the question of "how do I grab complex output on the CLI?"
Should be useful:
thufir@dur:~$
thufir@dur:~$ script xmas
Script started, file is xmas
thufir@dur:~$
thufir@dur:~$ echo Merry && echo Christmas
Merry
Christmas
thufir@dur:~$
thufir@dur:~$ exit
exit
Script done, file is xmas
thufir@dur:~$
thufir@dur:~$ cat xmas
Script started on 2017-10-27 06:37:59-0700
thufir@dur:~$
Merry
Christmas
thufir@dur:~$
thufir@dur:~$ exit
exit
Script done on 2017-10-27 06:38:23-0700
thufir@dur:~$
thufir@dur:~$ pastebinit xmas
http://paste.ubuntu.com/25830406/
thufir@dur:~$
Here's the pastebin file on ubuntu, as above. Reference man script for how to use typescript.
Note that you can execute scripts, interact, etc. The script command just logs everything into a file. Not quite sure how to make it more readable without futzing with the console/shell configuration...
Basically, if you turn off all colors, etc, it looks better.
Thufir
  • 4,631
