I have the same notebook and problem as the person here: Wifi problem with Ubuntu 14.04 and RTL8723ae
I have tried everything including the suggestions provided there (I installed the non-free drivers and WICD but no use. No wireless networks are shown in the list.
lshw -C network WARNING: you should run this program as super-user.
 *-network
        description: Wireless interface
        product: RTL8723AE PCIe Wireless Network Adapter
        vendor: Realtek Semiconductor Co., Ltd.
        physical id: 0
        bus info: pci@0000:01:00.0
        logical name: wlan0
        version: 00
        serial: 54:27:1e:d0:72:1f
        width: 64 bits
        clock: 33MHz
        capabilities: bus_master cap_list ethernet physical wireless
        configuration: broadcast=yes driver=rtl8723ae driverversion=3.13.0-43-generic firmware=N/A latency=0 link=no
multicast=yes wireless=IEEE 802.11bgn
       resources: irq:24 ioport:e000(size=256) memory:fea00000-fea03fff
dmesg | grep rtl [   13.865686] rtl8723ae: Using firmware
rtlwifi/rtl8723fw_B.bin [   13.986526] ieee80211 phy0: Selected rate
control algorithm 'rtl_rc' [   13.989656] rtlwifi: wireless switch is
on
What is the problem? I am clueless
Go into network manager at top right corner of the screen and click on edit connections > wireless tab and set IPV6 to ignore.
Now open the terminal CTRL+ALT+T then copy and paste the following code one line at a time for accuracy:
echo "options rtl8723ae swenc=1 ips=0" | sudo tee /etc/modprobe.d/rtl8723ae.conf
sudo modprobe -rfv rtl8723ae
sudo modprobe -v rtl8723ae
IF the issue persists, try compiling new driver. Hope this helps!
BDRSuite
  • 3,196
  • 13
