I tried uninstalling it from Ubuntu software center. It gets uninstalled but if I re-install Firefox (not developer edition) then it switches to Firefox developer edition.
How do I ONLY uninstall Firefox developer but keep the bookmarks, URL etc. saved for the retro Mozilla Firefox browser. I don't want to loose any data while shifting from Firefox developer edition to the Mozilla Firefox browser.
swapnesh
  • 191
5 Answers5
To remove the Firefox Developer Edition from ppa, use ppa-purge.
First close the Firefox Developer Edition, then run the following:
sudo apt-get install ppa-purge
And then remove the ppa:
sudo ppa-purge ppa:mozillateam/firefox-next
I am not sure if it will keep your Firefox data! But by using Firefox Sync, you can backup everything just in case it deletes everything.
After that remove packages that FDE required, but are no longer needs.
sudo apt-get autoremove
Then reinstall firefox:
sudo apt-get install firefox
Pilot6
  • 92,041
blade19899
  • 26,994
Had to uninstall this PPA. The rest of the instructions worked as expected, and my original Firefox profile was restored.
sudo ppa-purge  ppa:ubuntu-mozilla-daily/firefox-aurora
nullsteph
  • 423
For those who installed firefox developer edition using ubuntu-make, you can delete the symlink ~/.local/share/umake/bin/firefox-developer and the folder ~/.local/share/umake/web/firefox-dev.
If you want to unkinstall umake completely, run
sudo apt-get purge ubuntu-make
And then delete the folder ~/.local/share/umake, as the purge will not remove it.
On Fedora I was able to simply rename the 'firefox' directory, reinstall firefox and reimport my bookmarks. It is cleaner to remove the old directory if you prefer, but as they say if it works don't fix it.
Make sure all your Firefox specific data to your Firefox Account (if you don't have one, it is super easy to set up: go to the three horizontal bars in the tool bar and click where it will say something about sign-in to account to sync).
Then use apt to remove the dev version of Firefox. Be sure to run sudo apt autoremove to remove any leftover configuration files. (Personally, I would also reboot to ensure any old files are removed. But this is not entirely necessary). Then, go and use apt, synaptic, or the software center to re-install Firefox.
Finally, log into your Firefox Account and all your bookmarks, settings, and add-ons will be copied over to the new installation for you.
Hope this helped!
Batcastle
  • 290
