After moving to a new computer and reinstalling all that I had on my old one, I can compile a C++ program that's using GTK+3.0 in Anjuta but when I try to run it, I get the message
error while loading shared libraries: libgtkmm-3.0.so.1: cannot open shared object file: No such file or directory
I've spent a bit of time searching for an answer to this and have even reinstalled the package with improvement. What am I missing here? I find a link (I think this is correct term) to this file in /usr/lib/x86_64-linux-gnu. Do I need to copy this link somewhere else, update an environment variable (PKG_CONFIG_PATH or LD_LIBRARY_PATH), or what? (Both of the mentioned variables are currently empty.)
My old computer was a 32-bit system and this new one is 64-bit. I have only copied files - I have reinstalled all needed packages and programs. I did copy the Anjuta files when I copied the source directories.
Any suggestions to fix this issue will be greatly appreciated.
Anwar
  • 77,855
I got it working today! I believe this issue is related to my move to my new setup because the old laptop was a 32-bit processor and my new system is a 64-bit system.
I deleted all of the files and folders associated with Anjuta, leaving only my source and class files. I defined a new project, added the appropriate libraries, and the build and compile worked fine.
I have an issue with Anjuta running the program without debugging (it's looking for the executable in the debug directory but I built the code in the default configuration) but the program works if I run it manually.
