(EDITED 2x) Recently installed Ubuntu 14.10 x64 takes over 4 minutes to boot on the system below. I don't understand the 'dmesg' output; at first I thought a USB MS Mouse was a problem; replaced that with a Logitech mouse and still 4+ minutes. So is the delay here from the Nouveau driver trying to work with my nVidia card? Where is this "broken pipe" coming from? EDIT 2: I guess it is this bug: https://bugs.launchpad.net/ubuntu/+source/nvidia-graphics-drivers-304/+bug/1364630
One portion of dmesg output:
...trimmed... [ 14.948030] nouveau [ PTHERM][0000:01:00.0] FAN control: none / external [ 14.948041] nouveau [ PTHERM][0000:01:00.0] fan management: automatic [ 14.948044] nouveau [ PTHERM][0000:01:00.0] internal sensor: yes [ 14.948057] nouveau [ CLK][0000:01:00.0] 0f: core 650 MHz shader 1625 MHz memory 400 MHz [ 14.948104] nouveau [ CLK][0000:01:00.0] --: core 566 MHz shader 1400 MHz memory 499 MHz [ 14.948261] [TTM] Zone kernel: Available graphics memory: 2023128 kiB [ 14.948263] [TTM] Initializing pool allocator [ 14.948269] [TTM] Initializing DMA pool allocator [ 14.948279] nouveau [ DRM] VRAM: 512 MiB [ 14.948281] nouveau [ DRM] GART: 1048576 MiB [ 14.948284] nouveau [ DRM] TMDS table version 2.0 [ 14.948286] nouveau [ DRM] DCB version 4.0 [ 14.948288] nouveau [ DRM] DCB outp 00: 02000300 00000028 [ 14.948290] nouveau [ DRM] DCB outp 01: 01000302 00020030 [ 14.948291] nouveau [ DRM] DCB outp 02: 04011310 00000028 [ 14.948293] nouveau [ DRM] DCB outp 03: 010223f1 00c0c080 [ 14.948295] nouveau [ DRM] DCB conn 00: 00001030 [ 14.948297] nouveau [ DRM] DCB conn 01: 00000200 [ 14.948298] nouveau [ DRM] DCB conn 02: 00000110 [ 14.948299] nouveau [ DRM] DCB conn 03: 00000111 [ 14.948301] nouveau [ DRM] DCB conn 04: 00000113 [ 14.956768] nouveau W[ DRM] failed to create encoder 0/1/0: -19 [ 14.956770] nouveau W[ DRM] TV-1 has no encoders, removing [ 14.956834] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 14.956836] [drm] Driver supports precise vblank timestamp query. [ 14.969193] nouveau [ DRM] MM: using M2MF for buffer copies [ 15.030623] nouveau [ DRM] allocated 1280x1024 fb: 0x70000, bo ffff88012915d800 [ 15.030731] fbcon: nouveaufb (fb0) is primary device [ 15.092134] EXT4-fs (sdc7): re-mounted. Opts: errors=remount-ro [ 15.097810] Console: switching to colour frame buffer device 160x64 [ 15.098667] nouveau 0000:01:00.0: fb0: nouveaufb frame buffer device [ 15.098669] nouveau 0000:01:00.0: registered panic notifier [ 15.112037] [drm] Initialized nouveau 1.1.2 20120801 for 0000:01:00.0 on minor 0 [ 18.115446] WARNING! power/level is deprecated; use power/control instead [ 167.149871] init: Error while reading from descriptor: Broken pipe [ 167.154588] init: failsafe main process (688) killed by TERM signal [ 167.786696] audit: type=1400 audit(1419194421.420:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=834 comm="apparmor_parser" [ 167.786703] audit: type=1400 audit(1419194421.420:12): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=834 comm="apparmor_parser" [ 167.786707] audit: type=1400 audit(1419194421.420:13): apparmor="STATUS" operation="profile_load" profile="unconfined" name="third_party" pid=834 comm="apparmor_parser" [ 167.843884] audit: type=1400 audit(1419194421.476:14): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=836 comm="apparmor_parser" [ 167.843891] audit: type=1400 audit(1419194421.476:15): apparmor="STATUS" operation="profile_load" profile="unconfined" name="chromium" pid=836 comm="apparmor_parser" [ 167.845445] audit: type=1400 audit(1419194421.480:16): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/sbin/dhclient" pid=836 comm="apparmor_parser" [ 167.845451] audit: type=1400 audit(1419194421.480:17): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=836 comm="apparmor_parser" [ 167.845456] audit: type=1400 audit(1419194421.480:18): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=836 comm="apparmor_parser" [ 167.854293] audit: type=1400 audit(1419194421.488:19): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince" pid=836 comm="apparmor_parser" [ 167.854300] audit: type=1400 audit(1419194421.488:20): apparmor="STATUS" operation="profile_load" profile="unconfined" name="sanitized_helper" pid=836 comm="apparmor_parser" [ 168.015337] Bluetooth: Core ver 2.19 [ 168.015350] NET: Registered protocol family 31 [ 168.015351] Bluetooth: HCI device and connection manager initialized [ 168.015357] Bluetooth: HCI socket layer initialized [ 168.015359] Bluetooth: L2CAP socket layer initialized [ 168.015367] Bluetooth: SCO socket layer initialized [ 168.062156] Bluetooth: RFCOMM TTY layer initialized [ 168.062166] Bluetooth: RFCOMM socket layer initialized [ 168.062175] Bluetooth: RFCOMM ver 1.11 [ 168.076354] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 168.076357] Bluetooth: BNEP filters: protocol multicast [ 168.076365] Bluetooth: BNEP socket layer initialized [ 168.133543] init: cups main process (835) killed by HUP signal [ 168.133553] init: cups main process ended, respawning [ 169.256440] systemd-logind[1022]: New seat seat0. [ 169.269854] systemd-logind[1022]: Watching system buttons on /dev/input/event1 (Power Button) [ 169.269914] systemd-logind[1022]: Watching system buttons on /dev/input/event0 (Power Button) [ 169.409480] r8169 0000:04:00.0 eth0: link down [ 169.409704] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 169.425476] r8169 0000:05:00.0 eth1: link down [ 169.425489] r8169 0000:05:00.0 eth1: link down [ 169.425615] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 169.528376] init: nvidia-prime main process (1083) terminated with status 127 [ 171.473061] r8169 0000:05:00.0 eth1: link up [ 171.473071] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready [ 175.175873] init: plymouth-upstart-bridge main process ended, respawning [ 175.187370] init: plymouth-upstart-bridge main process ended, respawning [ 175.230395] systemd-logind[1022]: Failed to start unit user@112.service: Unknown unit: user@112.service [ 175.230400] systemd-logind[1022]: Failed to start user service: Unknown unit: user@112.service [ 175.234194] systemd-logind[1022]: New session c1 of user lightdm. [ 175.234210] systemd-logind[1022]: Linked /tmp/.X11-unix/X0 to /run/user/112/X11-display. [ 198.029026] audit_printk_skb: 45 callbacks suppressed [ 198.029029] audit: type=1400 audit(1419194451.664:36): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=1789 comm="apparmor_parser" [ 198.029036] audit: type=1400 audit(1419194451.664:37): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=1789 comm="apparmor_parser" [ 198.040134] audit: type=1400 audit(1419194451.676:38): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="third_party" pid=1789 comm="apparmor_parser" [ 244.836062] systemd-logind[1022]: Failed to start unit user@1000.service: Unknown unit: user@1000.service [ 244.836070] systemd-logind[1022]: Failed to start user service: Unknown unit: user@1000.service [ 244.845657] systemd-logind[1022]: New session c2 of user john. [ 244.845680] systemd-logind[1022]: Linked /tmp/.X11-unix/X0 to /run/user/1000/X11-display.
System Description (when I still had the MS mouse connected, but otherwise same):
Processor : 4x Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Memory : 4046MB (1194MB used) Operating System : Ubuntu 14.10 Date/Time : Sun 21 Dec 2014 11:58:51 AM PST -Display- Resolution : 1280x1024 pixels OpenGL Renderer : Unknown X11 Vendor : The X.Org Foundation -Multimedia- Audio Adapter : HDA-Intel - HDA Intel -Input Devices- Power Button Power Button Logitech Logitech USB Keyboard Logitech Logitech USB Keyboard HDA Intel Front Mic HDA Intel Rear Mic HDA Intel Line HDA Intel Line Out Front HDA Intel Line Out Surround HDA Intel Line Out CLFE HDA Intel Line Out Side HDA Intel Front Headphone Microsoft Microsoft Basic Optical Mouse v2.0 -SCSI Disks- SAMSUNG DVDWBD SH-B083L ATA MAXTOR STM350032 ATA MAXTOR STM350063 PLEXTOR DVDR PX-712A ATA Maxtor 6Y120P0 Generic USB SD Reader Generic USB MS Reader Operating System ---------------- Kernel : Linux 3.16.0-28-generic (x86_64) Compiled : #38-Ubuntu SMP Fri Dec 12 17:37:40 UTC 2014 C Library : Unknown Default C Compiler : GNU C Compiler version 4.9.1 (Ubuntu 4.9.1-16ubuntu6) Distribution : Ubuntu 14.10
