I have 3 GB of RAM. The output of lscpu:
Architecture: i686
CPU op-mode(s): 32-bit, 64-bit
Architecture: i686
By "32-bit machine" I understand 32-bit hardware (processor) which is not your case because lscpu reports that your CPU can work in 64-bit mode.
You have a 32-bit software (operating system) running at the moment on your PC, that's why:
Architecture: i686
But you can install a 64-bit operating system (you have both a compatible CPU and enough RAM for it).
You can install a 32 bit system on 64 bit hardware.
The converse is not true.
You cannot install a 64 bit system on 32 bit hardware.
From the output of lscpu you gave:
It looks like your hardware is in fact 64 bit. You can install a 64 bit system.
