I have Acer E1 572, and I want to install Ubuntu 14.04. instead of windows 8 will it work(Run) will it support A E1-572 correctly without any interruption :) thanks w
Give it a try!
To download, first see if you have a 32 bit or 64 bit OS
http://pcsupport.about.com/od/windows-8/a/windows-8-64-bit-32-bit.htm
Then, download the appropriate .iso
32 bit .iso
64 bit .iso
After dowloading the appropriate iso, download Linux Liveusb creator
Plug your flashdrive in, run Lili, and follow the instructions. Change source to an iso and find the file you downloaded earlier. Now, leave the flashdrive plugged in. Restart your computer and press the key to change boot order. Can be F12, F11, F9, F8, or DEL. Find the flash drive you're using and press enter.
Your trial of ubuntu is now running! You can play around, install things, and do whatever. If you see any problems, the people here are normally more than willing to help you. When done, remove the flash drive and restart. Should go back to normal function.
- 505
