WHen I close the lid, it suspends, but when I open it again, the screen stays full black. If I hit the power button, occasionally it will come back to life but sometimes i have to force a reboot unfortunately.
Asked
Active
Viewed 1,783 times
All thanks to linvinus on reddit: How to make hibernate working in ubuntu 14.04 on Acer c720
How to make hibernate working in ubuntu 14.04 on Acer c720, tested in HP Chromebook 14 on Ubuntu 14.10 kernel 3.17 as well, works. He has Lubuntu 14.04 kernel 3.13.0-24-generic c720 2G. For Debian, Arch, or Xubuntu, there are more instructions in the source link.
Takes about 5 mins to do, but works like a charm for me,
create file
sudo nano /etc/initramfs-tools/scripts/init-top/unbind_ehciwith following content
##################### #!/bin/sh PREREQ="" prereqs() { echo "${PREREQ}" } case ${1} in prereqs) prereqs exit 0 ;; esac log_success_msg "Unbind ehci for preventing error" echo -n "0000:00:1d.0" > /sys/bus/pci/drivers/ehci-pci/unbind exit 0 #################change mode
sudo chmod a+x /etc/initramfs-tools/scripts/init-top/unbind_ehcicreate udev rule
sudo nano /etc/udev/rules.d/10_disable-ehci.rules ACTION=="add", SUBSYSTEM=="pci", DRIVER=="ehci_hcd", \ RUN+="/bin/sh -c 'echo -n %k > %S%p/driver/unbind'"update initramfs
sudo update-initramfs -k all -uthis script will fix touchpad after resume
sudo nano /etc/pm/sleep.d/99zcyapawith following content
##################### #!/bin/bash -x # File: "/etc/pm/sleep.d/99_cyapa". case "${1}" in hibernate) /sbin/rmmod cyapa ;; resume|thaw) COUNTER=0 while [ $COUNTER -lt 10 ]; do date >>/tmp/99_cyapa /sbin/modprobe cyapa sleep 1 dmesg | grep cyapa | tail -1 | grep error >/dev/null RES=$? echo "res=$RES" if [ ${RES} -ne 1 ] ; then /sbin/rmmod cyapa sleep 1 else #done COUNTER=11 fi COUNTER=`expr $COUNTER + 1` done ;; esac exit 0 #################Change mode!
sudo chmod a+x /etc/pm/sleep.d/99zcyapaensure that in you have
tpm_tis.interrupts=0sudo nano /etc/default/grubthere is my settings
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash boot=local i915.modeset=1 tpm_tis.interrupts=0 "update grub
sudo update-grub2Reboot
Again thanks to linvinus on reddit
LiveWireBT
- 29,597
Jonathan
- 3,984
