I need to create an encrypted channel between two computers inside a lan using openswan, so I can show how the encrypted traffic is using wireshark. I installed openswan in both computers (running ubuntu), and read a lot of forums (this is my first vpn creation) and I tried to set up everything but still can't ping any machine from the other...this is the configuration file :
version 2.0 # conforms to second version of ipsec.conf specification
# basic configuration
config setup
dumpdir=/var/run/pluto/
nat_traversal=yes
virtual_private=%v4:10.0.0.0/8,%v4:172.16.0.0/12,%v4:25.0.0.0/8,%v6:fd00::/8,%v6:fe80::/10
oe=off
protostack=auto
# Add connections here
conn demo-connection-debian
authby=secret
auto=start
keyexchange=ike
esp=3des-md5
pfs=yes
type=transport
left=192.168.1.102
right=192.168.1.105
in each computer I changed left for right so left was the local machine ip, did the same in ipsec.secrets in each machine that looks like :
include /var/lib/openswan/ipsec.secrets.inc
192.168.1.102 192.168.1.105: PSK "mypassword"
and I also removed 192.168.. from virtual_private in ipsec.conf, since I read in a forum that the ip server couldn't be there. I also read that if it was a point to point connection without a subnet you should use type=transport. When I run ipsec verify in one machine shows everything ok (the one that has only one network adapter), the other one that has wireless and ethernet shows:
Checking your system to see if IPsec got installed and started correctly:
Version check and ipsec on-path [OK]
Linux Openswan U2.6.38/K3.13.0-35-generic (netkey)
Checking for IPsec support in kernel [OK]
SAref kernel support [N/A]
NETKEY: Testing XFRM related proc values [OK]
[OK]
[OK]
Checking that pluto is running [OK]
Pluto listening for IKE on udp 500 [OK]
Pluto listening for NAT-T on udp 4500 [OK]
Two or more interfaces found, checking IP forwarding [FAILED]
Checking NAT and MASQUERADEing [OK]
Checking for 'ip' command [OK]
Checking /bin/sh is not /bin/dash [WARNING]
Checking for 'iptables' command [OK]
Opportunistic Encryption Support [DISABLED]
But i tried everything on google to fix it, and here I read that that doesnt matter since it was and perl error that could be ignored : https://serverfault.com/questions/619115/ipsec-verify-on-ubuntu-two-or-more-interfaces-found-checking-ip-forwarding-fai
So I have no any idea what is wrong and I wasted so many hours trying with no results, any help would be really appreciated, thanks a lot
