This seems to be a common problem area from all the other questions and answers but none of them seem to address my specific problem.
After several upgrades my server boot partition filled up. Apparently the system continued to try to upgrade and is now in some sort of vicious circle. I can't upgrade because of an unmatched dependency and I can't clean because of a pending upgrade.
I manually removed several old files to provide space, following suggestions in other answered questions (listed versions and rm'ed five oldest) but the problem persists. Here's what happens if I try to fix the install:
$ sudo apt-get -f install
Reading package lists... Done
Building dependency tree
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  linux-image-3.2.0-60-generic linux-headers-3.2.0-65-generic
  linux-image-3.2.0-63-generic linux-image-3.2.0-58-generic
  linux-headers-3.2.0-60 linux-headers-3.2.0-61 linux-headers-3.2.0-63
  linux-headers-3.2.0-58 linux-headers-3.2.0-64 linux-headers-3.2.0-59
  linux-headers-3.2.0-65 linux-headers-3.2.0-60-generic
  linux-headers-3.2.0-63-generic linux-headers-3.2.0-58-generic
  linux-image-3.2.0-61-generic linux-image-3.2.0-64-generic
  linux-image-3.2.0-59-generic linux-headers-3.2.0-61-generic
  linux-headers-3.2.0-64-generic linux-headers-3.2.0-59-generic
  linux-image-3.2.0-65-generic
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
  linux-server
The following packages will be upgraded:
  linux-server
1 upgraded, 0 newly installed, 0 to remove and 158 not upgraded.
1 not fully installed or removed.
Need to get 0 B/1,736 B of archives.
After this operation, 0 B of additional disk space will be used.
    Do you want to continue [Y/n]? y
dpkg: dependency problems prevent configuration of linux-server:
 linux-server depends on linux-image-server (= 3.2.0.68.81); however:
  Version of linux-image-server on system is 3.2.0.74.88.
 linux-server depends on linux-headers-server (= 3.2.0.68.81); however:
  Version of linux-headers-server on system is 3.2.0.74.88.
dpkg: error processing linux-server (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates it's a follow-up error from a     previous failure.
 linux-server
You'll see I've tried this before...
Tried autoremove, clean, autoclean, configure.
If it is any sort of a clue, about half the time when I run that command I lose the terminal session!
$ df -h /boot
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda1       228M  107M  109M  50% /boot
and all operations involving apt-get or dpkg fail with an error similar to the above.
Zanna
  • 72,312
Ian
I finally found the answer in this similar question: APT wedged by kernel version mismatch
I manually installed linux-server 3.2.0.74.88 as shown in the answer to that question and everything was sorted. Many thanks to Eliah Kagan for a thoughtful, useful and comprehensive answer.
Ian
