I am very new to Linux, so please forgive me if the answer to my question is obvious. Since I am running an ARM device and can't install wine, I am trying to install Mono/Develop. The problem is, whenever I try to install any of the Mono packages, I am greeted with a huge block of "unmet dependencies." For example:
(precise).....@localhost:~$ sudo apt-get install monodevelop
 monodevelop : Depends: mono-runtime-sgen but it is not going to be installed
               Depends: mono-runtime (>= 3.0~) but it is not going to be installed
               Depends: libgconf2.0-cil (>= 2.24.0) but it is not going to be installed
               Depends: libglade2.0-cil (>= 2.12.10-1ubuntu1) but it is not going to be installed
               Depends: libglib2.0-cil (>= 2.12.10-1ubuntu1) but it is not going to be installed
               Depends: libgnome-vfs2.0-cil (>= 2.24.0) but it is not going to be installed
               Depends: libgnome2.24-cil (>= 2.24.0) but it is not going to be installed
               Depends: libgtk2.0-cil (>= 2.12.10-1ubuntu1) but it is not going to be installed
               Depends: libmono-cairo4.0-cil (>= 3.2.1) but it is not going to be installed
               Depends: libmono-corlib2.0-cil (>= 3.2.8) but it is not going to be installed
               Depends: libmono-corlib4.5-cil (>= 3.6.0) but it is not going to be installed
               Depends: libmono-microsoft-build-engine4.0-cil (>= 3.2.1) but it is not going to be installed
               Depends: libmono-microsoft-build-framework4.0-cil (>= 3.6.0) but it is not going to be installed
               Depends: libmono-microsoft-build-utilities-v4.0-4.0-cil (>= 3.6.0) but it is not going to be installed
               Depends: libmono-microsoft-csharp4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-posix4.0-cil (>= 3.2.3) but it is not going to be installed
               Depends: libmono-sharpzip4.84-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-componentmodel-dataannotations4.0-cil (>= 3.2.3) but it is not going to be installed
               Depends: libmono-system-configuration4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-core4.0-cil (>= 3.2.8) but it is not going to be installed
               Depends: libmono-system-data-services-client4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-data4.0-cil (>= 3.0.6) but it is not going to be installed
               Depends: libmono-system-design4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-drawing4.0-cil (>= 3.0.6) but it is not going to be installed
               Depends: libmono-system-runtime-serialization4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-runtime4.0-cil (>= 2.10.1) but it is not going to be installed
               Depends: libmono-system-security4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-servicemodel4.0a-cil (>= 3.2.3) but it is not going to be installed
               Depends: libmono-system-web-mvc3.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-web-razor2.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-web-services4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-web-webpages-razor2.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-web4.0-cil (>= 2.10.3) but it is not going to be installed
               Depends: libmono-system-windows-forms4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-xaml4.0-cil (>= 1.0) but it is not going to be installed
               Depends: libmono-system-xml-linq4.0-cil (>= 3.0.6) but it is not going to be installed
               Depends: libmono-system-xml4.0-cil (>= 3.6.0) but it is not going to be installed
               Depends: libmono-system2.0-cil (>= 3.2.1) but it is not going to be installed
               Depends: libmono-system4.0-cil (>= 3.2.8) but it is not going to be installed
               Depends: libmono-windowsbase4.0-cil (>= 3.0.6) but it is not going to be installed
               Depends: monodoc-base (>= 3.2.1) but it is not going to be installed
               Recommends: libglade2.0-cil-dev but it is not going to be installed
               Recommends: libgtk2.0-cil-dev but it is not going to be installed
               Recommends: mono-devel but it is not going to be installed
And at the end, I get this error:
The same thing happens when I try installing other packages such as mono-complete, but to a lesser extent.
(precise).....@localhost:~$ sudo apt-get install mono-complete
 mono-complete : Depends: mono-runtime (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-runtime-sgen (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-utils (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-devel (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-mcs (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-gmcs (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-dmcs (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-csharp-shell (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-2.0-gac (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-4.0-gac (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-2.0-service (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: mono-4.0-service (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: monodoc-base (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
                 Depends: monodoc-manual (= 2.10.8.1-1ubuntu2.2) but 3.10.0-0xamarin2 is to be installed
                 Depends: libmono-cil-dev (= 2.10.8.1-1ubuntu2.2) but it is not going to be installed
I have tried following the instructions on http://www.howtogeek.com/howto/linux/installing-monodevelop-from-source-on-ubuntu/, on Mono-Project, and MonoDevelop, and running sudo apt-get update, but I keep getting that broken packages error.
Do I have to reinstall Ubuntu (which is fine with me, since I'm using Crouton), add all of those package names to sudo-apt-get install, or what?
