Just got my laptop and Ubuntu was already installed when I switched it on. I don't know my username nor password, no disk / paper was included. So I can't install applications or run this program normally. What can I do to learn a password? I even can't restart or switch off my device to change it.
Asked
Active
Viewed 89 times
What would be the use of the password if anyone could read it? Of cause you can't. In your situation there are two ways:
- Reinstall Ubuntu. I recommend it because this way you will both get all the settings right and be sure nobody left a nasty trick in your machine, intentionally or not.
- Boot from live CD. Then chroot into your system and change passwd. Here are instructions. If you follow them , keep in mind that your disk name may be different from
/dev/sda1, uselsblkutility (in LiveCD) to check.
Barafu Albino
- 6,629
