I mounted a disk at /data. This is empty at the moment.
I need rsync to perform mkdir -p than mkdir as the file I needs to be at at level 4 i.e. /data/dir_1/dir_2/dir_3/filename when dir_1, dir_2 and dir_3 doesn't exists.
If I create the needed sub-directories manually I am able to perform rsync using following command:
rsync -avz source_diretory/ /data/dir_1/dir_2/dir_3
But if I don't create the sub directories, this command throws an error:
mkdir: cannot create directory ‘/data/dir_1/dir_2/dir_3/’: No such file or directory
I tried Googling, reading rsync's man page, tried using -r -R but could not make it work.
Can rsync perform something like mkdir -p or is that out of its scope?
rsync command doesn't create directory tree, so you can do this by perform:
 mkdir -p /data/dir_1/dir_2/dir_3
before rsync command or use --rsync-path options:
--rsync-path=PROGRAM Use this to specify what program is to be run on the remote machine to start-up rsync.
Your command should be:
 rsync -avz source_diretory/ --rsync-path="mkdir -p /data/dir_1/dir_2/dir_3 && rsync" /data/dir_1/dir_2/dir_3
Here is a useful link.
user.dz
  • 49,176
Lety
  • 6,089
  • 32
  • 38
A shorter way in Linux to create rsync destination paths is to use the '$_' Special Variable. (I think, but cannot confirm, that it is also the same in OSX).
'$_' holds the value of the last argument of the previous command executed. So the question could be answered with:
mkdir -p /data/dir_1/dir_2/dir_3 && rsync -avz source_directory/ $_
Dig
  • 341
