As the title, I have this file in root folder and I don't know what it is. Can I safely remove it?
-rw-------  1 root root 925M lug 22 15:28 tmpTKb8nhN6ke4IJ bnWrrgcIz-iyhS8H5V BAqFJNM7B.inBl47bd2TO_4xQ nwDtZ9UL7LK jOZc7DjhEQBRuqQ Q9SY0hIlqGh.7Tt1zkIFTgd9cjDUv38OXO-01ouoaFA4ZfqxlEkUT8AEveVA7wZazcLqa4Jg4ywe3JVY-6WYUg8e_t_XH9AooVQFm_hteSzoQmEw3iyEGDFHXkQsY iwyQ0ZqLI3lEPhsvktp9-tzE..dDvL8snJt5Oe
tigerjack
  • 2,635
If your question is really "Will deleting this file damage my system?" No, deleting the file won't damage your system. But we don't know anything about the services and data ON your system.
Do just a little more investigation first:
When was it saved? (in Italian, for example, 'lug 22' its almost 5 months ago) Do you remember what big changes you wrought as root back then? Do you remember if you might have created some backups?
Also, make another test:
Change the file's name. If after a normal backup cycle and a reboot cycle, your still don't need that file, then you have additional data to base your decision upon.
user535733
  • 68,493
After a couple of tries, I finally found the problem. When I run bleachbit as root, it automatically creates files with similar names. I don't know which kind of options cause this, I'm still investigating.
EDIT: take a look at this Strange folder in my home folder after a failed run of BleachBit and this http://bleachbit.sourceforge.net/forum/bleachbit-wipe-free-disk-space-doesnt-work
In short, it seems that it is a bug of the "Wipe free space" option of Bleachbit (as root) 1.0. You can download the new version from their site http://bleachbit.sourceforge.net/download/linux
tigerjack
  • 2,635
