I'm using 64-bit Ubuntu 12.04 LTS on my machine. I've already installed LAMP server on my machine.
I'm using following Apache HTTP Server version.
I got following information after I type following command into my machine's terminal :
apachectl -V
Server version: Apache/2.4.10 (Ubuntu)
Server built:   Jul 22 2014 22:57:50
Server's Module Magic Number: 20120211:36
Server loaded:  APR 1.5.1, APR-UTIL 1.5.3
Compiled using: APR 1.5.1, APR-UTIL 1.5.3
Architecture:   64-bit
Server MPM:     prefork
  threaded:     no
    forked:     yes (variable process count)
Server compiled with....
 -D APR_HAS_SENDFILE
 -D APR_HAS_MMAP
 -D APR_HAVE_IPV6 (IPv4-mapped addresses enabled)
 -D APR_USE_SYSVSEM_SERIALIZE
 -D APR_USE_PTHREAD_SERIALIZE
 -D SINGLE_LISTEN_UNSERIALIZED_ACCEPT
 -D APR_HAS_OTHER_CHILD
 -D AP_HAVE_RELIABLE_PIPED_LOGS
 -D DYNAMIC_MODULE_LIMIT=256
 -D HTTPD_ROOT="/etc/apache2"
 -D SUEXEC_BIN="/usr/lib/apache2/suexec"
 -D DEFAULT_PIDLOG="/var/run/apache2.pid"
 -D DEFAULT_SCOREBOARD="logs/apache_runtime_status"
 -D DEFAULT_ERRORLOG="logs/error_log"
 -D AP_TYPES_CONFIG_FILE="mime.types"
 -D SERVER_CONFIG_FILE="apache2.conf"
I'm using following PHP version on my machine. Following is the command that I run and the information I seen:
php -v
PHP 5.5.19-1+deb.sury.org~precise+1 (cli) (built: Nov 19 2014 19:32:34)
Copyright (c) 1997-2014 The PHP Group
Zend Engine v2.5.0, Copyright (c) 1998-2014 Zend Technologies
    with Zend OPcache v7.0.4-dev, Copyright (c) 1999-2014, by Zend Technologies
When I hit the URL : http://localhost/phpmyadmin from the address bar of my browser, Log in screen of phpMyAdmin loaded then I entered the Username and Password to login. After logging in I saw following details on right pane.
**MySQL**
 - Server: Localhost via UNIX socket
 - Server version: 5.5.40-0ubuntu0.12.04.1
 - Protocol version: 10
 - User: root@localhost
 - MySQL charset: UTF-8 Unicode (utf8)
**Web server**
 - Apache/2.4.10 (Ubuntu)
 - MySQL client version: 5.5.40
 - PHP extension: mysqli
**phpMyAdmin**
 - Version information: 3.4.10.1deb1
 - Documentation
 - Wiki
 - Official Homepage
 - Contribute
 - Get support
 - List of changes
I don't know whether the versions of softwares MySQL Server, MySQL Client and phpMyAdmin are the latest stable versions or not. Please guide me in this regard.
Now I want to update MySQL Server, MySQL Client and phpMyAdmin to the latest stable versions on my local machine that is running on 64-bit Ubuntu 12.04 LTS.
What should be the efficient, reliable, secure and easiest way to do this?
Please provide me help in this regard.
Thanks in advance.
PHPLover
  • 1,807
I would expect from an Ubuntu LTS release such as yours to have the latest stable version of all those software you mentioned. You are 2-years into the 5-years support period of your release, so I think this is a reasonable expectation.
Upgrading to 14.04 doesn't seem like a great idea. Upgrading is a sensitive operation not to be taken lightly, potentially a major hurdle. The support period of 14.04 will end one year earlier than the current, so you would have to upgrade one year earlier.
To update the software you listed, you can use this command:
apt-get install names_of_packages
This will upgrade only the selected packages. If you don't mind, it's good to keep your entire system up to date, with:
apt-get upgrade
If, on the other hand, the version of Apache/MySQL bundled with 12.04 is really too old for you, then you might want to consider installing the latest version from source. However at this point the benefits of this approach over upgrading to 14.04 become questionable.
In any case, before you do any major changes (apt-get install or apt-get upgrade don't count as major changes, they should be safe), I recommend to create a clone system (in VirtualBox or other), export your current settings and reimport in the clone and test carefully.
janos
  • 4,968
