59
I installed Firestarter, and configured my firewall.
But I'm in doubt : On boot, I sometimes see a [FAIL] marker, and to the left, I guess it was something like "start firewall". I can't be sure because the message is seen for less than a second, so I wanted to know if there is a way, without starting the whole firestarter software, to know if the firewall is on and working, or not.
Either a gadget, or better, some console instruction, the exact name of the firewall process/daemon, or bash script, will do.
Edit: I already tested my computer with the "Shield's Up" http://www.grc.com feature, which marks my computer as "Stealth", but as I am behind a router, I'm not surprised. Still, apparently, my computer answers to pings... Strange...
htorque
  • 66,086
paercebal
  • 691
5 Answers5
50
There are basically 2 ways of seeing if the firewall is configured. You should use both of the methods and verify that the firewall is both configured and configured the way you wish it to be.
First, check that the firewall rules have been applied. Pretty much all modern Linux firewall solutions use iptables for firewall. You can see that there are rules in place with iptables command:
iptables -L
This will return the current set of rules. There can be a few rules in the set even if your firewall rules haven't been applied. Just look for lines that match your given rulesets. This will give you an idea of what rules have been entered to the system. this doesn't guarantee the validity of the rules, only that they have been understood.
Next, you will use a second computer to test for connections against the host in question. This can be easily done with the nmap command (found in nmap package). Quick and dirty way of checking is:
nmap -P0 10.0.0.10
nmap -P0 -sU 10.0.0.10
Replace the IP address 10.0.0.10 with your destination hosts IP address.
The first line will scan for TCP ports that are open and available from the second computer. Second line will repeat the scan but this time with UDP ports. -P0 flag will prevent the host from being tested with a ICMP Echo packet, but might be blocked by your firewall rules.
The scan might take a while so be patient. There is also a GUI frontend for nmap called zenmap which makes it a bit easier to interpret the scan results if there is a lot of output.
Ressu
  • 14,086
41
You can use this command:
ufw status
kiri
  • 28,986
windox
  • 411
To check Firewall status use command:
sudo ufw status
To enable the firewall use command:
sudo ufw enable
To disable the firewall use command:
sudo ufw disable
Oli
  • 299,380
First of all, you can review the syslog for any error messages from services with sudo less /var/log/syslog. That may give you a clue as to why the firestarter service didn't start.
You can manipulate services with the service command. To check whether a service runs, use service [service_name] status. In your case, I guess service_name is just firestarter. You can use tab-completion to get a list of available services (service TAB TAB), or take a look at the contents of directory /etc/init.d (every file is a script to manage a service).
Ubuntu has its own firewall system, called Uncomplicated Firewall (ufw). Maybe it's easier to use that one within Ubuntu. If you install the package gufw, you can access the configuration in System -> Administration -> Firewall configuration.
The iptables command mentioned above works on any Linux system. All Linux firewall configuration tools (like ufw, firestarter, and many others) are basically front-ends to iptables.
Question On boot, I sometimes see a [FAIL] marker, and to the left, I guess it was something like "start firewall". I can't be sure because the message is seen for less than a second
All the above answers are complete in themselves and can solve the problem. But here's a little advice from me
Before we start our debugging process, we must analyze the problem description carefully, so you can use slow motion mode of mobile's camera to see what exactly is the error message.
HeRo
