I just created a new user, and I want to give access to a folder.
I have done:
chmod -R 777 ./p
and this is the result
lisa@linux:/media$ ls -halt
drwxr-xr-x  27 root      root   4,0K dic 11 11:57 ..
drwxrwxrwx+  3 pierpaolo utenti 4,0K dic  8 23:48 p
drwxr-xr-x   3 root      root   4,0K set 10 12:20 .
lrwxrwxrwx   1 root      root     45 ago  5 01:22 .directory -> /etc/kubuntu-default-settings/directory-media
But still, i can not cd in to the folder (permission denied). Any idea how to approach this problem or debug it?
Edit:
getacl gives:
# file: p
# owner: pierpaolo
# group: utenti
user::rwx
user:pierpaolo:r-x
group::---
mask::rwx
other::rwx
Edit: The folder i want to access by the new user is a second hard disk that has been mounted in /etc/fstab using the following command:
UUID=FEB222A8B222657D /media/p/Seagate  ntfs-3g  defaults,windows_names,locale=it_IT.UTF-8  0 0
Pierpaolo
  • 161
This happens because there is a directory higher in the tree where you do not have execute permission. If a parent directory has no execute permission for some user, then that user cannot stat any subdirectories regardless of the permissions on those subdirectories.
Example:
$ ls -l cake
drwxr-xr-x 2 zanna zanna 4096 Jul 12 11:43 brownies
$ chmod 666 cake
$ ls -l cake/brownies
ls: cannot access 'cake/brownies': Permission Denied
Even though I am the owner of the directory 'brownies' and all users have permission to read and enter it, I can't access it if its parent directory has no execute permission.
It's better to use groups to manage permissions than give to give directories 777 permission.
-2
acl are not exactly unix/linux standard. I know RH keeps trying to push them but they confuse more then they help. I would strip the ACL data and just use chmod/chown/chgrp.
setfacl --remove-all p   # see if that works.
csgeek
  • 1,659
