I am having trouble with getting my wifi to work. I installed ubuntu alongside windows 8.1 (Its really weird, I choose UEFI mode to go into windows and legacy mode to go into Ubuntu 12.04). Anyhow the only internet that I can get is a wired internet connection and my home wifi (I added that when installing). There is no wifi icon in the top bar but I am connected to our home wifi because I can load webpages. The driver I would need is Realtek RLT8188ee, which has no linux variation available. I tried this guide here Wireless not working on Toshiba Satellite C55-A5281 .
Every thing was fine until I ran the make and sudo make install commands. Errors are here https://i.sstatic.net/rhXC2.png (red is make blue is sudo make install, these were the only errors I saw).
In case anyone cares I ran uname -mr in terminal and this came out 3.13.0-41-generic x86_64
I also ran the final command sudo modprobe rlt8188ee and it just returned to a command line, like what happens when a command is done, so i assumed that worked or depended on the previous commands to work.
So what do I do? How do I fix the driver? I'm not the most advanced in Ubuntu so if you could break things down a little more, or even explain what it does that would be great.
Oh and this is AMD architecture
As asked by chili555 I ran those commands and pasted the results here: http://paste.ubuntu.com/9503274/ The first block was the first command and so on and so forth.
Thought I'd give an update: The wifi is now working after I ran updates and restarted. I still cannot see wifi options and status in the top bar, but i can see it in settings->network.
Sorry to waste your time.
Although the link you gave asks that you compile backports-3.11, you compiled the much older and incompatible backports-3.2. In fact, rtl8188ee is included in Ubuntu 14.04, which uses kernel 3.13, by default! There is no need to compile anything:
ubuntu@ubuntu:~$ modinfo rtl8188ee
filename:       /lib/modules/3.13.0-24-generic/kernel/drivers/net/wireless/rtlwifi/rtl8188ee/rtl8188ee.ko
firmware:       rtlwifi/rtl8188efw.bin
description:    Realtek 8188E 802.11n PCI wireless
license:        GPL
Please give us some diagnostics so we may see what is going wrong:
lspci -nn | grep 0280
rfkill list all
dmesg | grep rtl
As the results may be lengthy, please paste them here and give us the link: http://paste.ubuntu.com. I will then edit this answer to propose a solution.
chili555
  • 61,330
Apparently, the driver was working better a few releases ago, so the backport driver was not that bad of a suggestion. I tried it, and it worked better than the one in the 3.13.0-32 kernel. However, the new driver that Larry Finger has seems to work far better than either one. You can find directions here
danlG
  • 31
