My DELL 27inch monitor should be capable of 2560x1440 resolution. I've confirmed with Ubuntu 12.04 NVIDIA with DVI connection. Now on 14.04 IntelĀ® HD 4600 with HDMI, the maximum resolution I see is only 1920x1080.
$ xrandr
VGA1 disconnected (normal left inverted right x axis y axis)
HDMI1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
   1920x1080      60.0*+   60.0     50.0     59.9     24.0     24.0
   1920x1080i     60.1     50.0     60.0
   1600x1200      60.0
Among many similar issues on askubuntu.com, I saw this one gives a command set that seems kind of promising, but after xrandr --output HDMI1 --mode 2560x1440, the OS' display setting tool says the display got 2560x1440 (that's what I want) but the DELL monitor got blacked-off and stated:
Current input timing is not supported by the monitor display. Please change your input timing to 1920x1080@60Hz or any other monitor listed timing as per the monitor spec.
How can I get 2560x1440 on my external DELL monitor?
IsaacS
  • 1,106
