When I use Fedora if I press the super key I get the view of all the applications i'm using, and it's very comfortable, is there a way of having this on Ubuntu?
Thanks.
Thanks.
As noted in the comments, if you want things to function the exact same way as in Fedora, you'll have to use GNOME, not Ubuntu's default Unity.
However, in Unity you can display all the windows open on a given workspace by hitting Super+W. If you want to see all the windows on all workspaces, hold Shift+Super, then hit W.
Holding Super will bring up Unity's keyboard shortcut list, where these commands and other similar ones are listed. The spread commands can also be configured using the Scale plugin of the CompizCongig Settings Manager. There you can change the shortcut keys and set hot corners to bring up the window spread.
