I just upgraded from 3.13.0-40 to 3.13.0-43, and now I can't boot- my system hangs at the ubuntu splash screen with the five orange dots. My fans are all running full-tilt, and the system is completely unresponsive- I can't ctrl-alt-f1 into a command prompt.
I'm sure this is related to the upgrade, because I can still boot into 3.13.0-40 just fine. I've tried reinstalling linux-generic and linux-image-generic, it didn't change anything.
When I look in syslog, there appear to be no entries at all from the failed boot.
How can I troubleshoot what it is about this kernel version that's causing my system to hang?
System specs: Ubuntu 14.04, AMD Radeon HD 7750 graphics card, using the open-source drivers
Introduction
I also had the same problem after an update on a AMD A6-6400 processor with a Radeon HD GPU. Got the black screen of death (BSOD). I was able to boot up (sometimes) holding down the shift key to display the GRUB menu, selecting "Advanced options for Ubuntu" and then selecting a previous version of the kernel (3.13.0-40-generic).
Update V - System rebuild
My AMD processor is mounted on a Gigabyte GA-F2A88XN-blah-blah-blah motherboard with retrofit quiet cooling components. I hate noise. I like this system when it works properly because I can't hear it. Don't suggest I change the hardware. That is not going to happen.
The Old System
I had Ubuntu 14.04 LTS (32 bit) installed with the proprietary fglrx drivers enabled. The open source drivers used too much CPU power. I could hear the fans. The open source drivers sucked.
This fglrx configuration worked fine for about a year. Then the 14.04 automatic updates stopped working. More BSOD bullshit. That kind of thing. Enough is enough.
The New System
The new system started with Ubuntu 15.10 (64 bit) installed with the open-source drivers enabled. Everything seemed to work. I then enabled the fglrx drivers. Everything seemed to work. WooHoo. Time for lunch.
For some reason, after some time had passed, the custom cooling fans began to run at maximum speed. My black box was noisy and annoying.
The sun was shining on the box and it was a warm day, but the CPU should have been napping. Now it sounded like it was competing in the Tour-de-France.
I powered up the TV, turned on the remote keyboard. Make sure the proper HDMI input is selected. This takes probably 45 seconds. The box, meanwhile, is screaming for air. The Black Screen Of Death (BSOD) is the only response. This procedure takes more than 45 seconds.
So I press & hold the front-panel power button. I count to 10. Slowly. Nothing happens. WTF?!? I wait a bit more because I don't know what to do. Never had this happen before.
So then I pull the power cord.
Recovery from this condition is a bit complicated, but it can be done. I would tell you how I did this but I forget now and Your Mileage May Vary (YMMV) anyway. Just ask Volkswagon.
Short version: AMD A6-6400 on a Gigabyte GA-F2A... motherboard? Install Ubuntu 15.10 64 bit. Use the open source drivers. That works best.
Update IV
I have since altered a line in /etc/default/grub from
GRUB_DEFAULT=0
to
GRUB_DEFAULT="Advanced options for Ubuntu>Ubuntu, with Linux 3.13.0-40-generic"
Note the text in the quotation marks is the exact same text as it appears on the 2 levels of GRUB menus. Adjust according to what appears on your own display.
After saving the edit, run the command:
sudo update-grub
This is not a solution of course, just a workaround, but at least it does boot up normally and everything seems to work. I hope a future update will make this problem go away. This last update was a total nightmare!
Update III
The latest kernel update (3.13.0.45) crippled my system. I am now using the latest AMD proprietary drivers and everything works again. This was another painful update. So now I'm thinking of using something other than Ubuntu. Seriously.
Update II
As reported below, the latest Linux kernel update (3.13.0-44) corrected the problem for me because I apparently use the Radeon driver. The problem was reported Dec 14 but it took almost a full month to correct the problem.
But wait! There's more! Apparently Kernel 3.13.0-44 has problems with NVIDIA drivers.
https://bugs.launchpad.net/ubuntu/+source/nvidia-graphics-drivers-331-updates/+bug/1409801
Update I
This morning (Jan 13) the software updater downloaded Linux kernel 3.13.0-44. It works on the A6-6400 on reboot. The file /etc/default/grub is back to its original form.
For the record, I also attempted to use several variations of the AMD fglrx suite of packages. It worked with the both the -40 and -43 releases BUT the rendered display was the wrong size! It turned a 50" HD TV into a 46" HD-ready TV. The smaller display was centered within the 50" display area. Very strange.
kos
  • 41,268
Diogenes
  • 147
1) I chose and boot 3.13.0-39.
2) Then I turned fglrx proprietary
3) And reboot in 3.13.0-43, thats work
P.S. sorry for my googletranslation
P.P.S System: Ubuntu 14.04.1 LTS i686 Kernel: 3.13.0-43-generic DE: Unity Session: ubuntu Processor: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz Video: 01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Juniper PRO [Radeon HD 6750] Subsystem: Hightech Information System Ltd. Device 2313 Kernel driver in use: fglrx_pci
Same here, Athlon 5150 with radeon R3 (HD8400). Black screen, system freeze during boot, started after upgrade of Ubuntu (this upgrade is included into installation of Ubuntu(!!!) )
Here is the bug report: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1402386
The worse is, the kernel 3.16.0-28 is also plagued by this bug.
T.Kijas
  • 64
I'm having the exact same issue with an NVIDIA card (gtx770 and proprietary drivers) and the lowlatency kernel!
I did not have the time to examine the problem here, but the result is the same so they may be related... I'm not able to access any other TTY, but using ssh I was able to conntect to the PC. I hope to find some time tomorrow.
lucaelin
  • 103
