I am running a command say nmap www.somesite.com>file.txt so that i can get the output to file.txt. But if I do so, I am not able to see the output of that command on terminal. Is it possible to make it visble on terminal also.
I know the usage of tee, but I wish to do this specifically in this way.
Anandu M Das
  • 2,303
tee is designed to split STDIN into a file and back out to STDOUT.
In simple terms, just pipe it through, like so:
nmap www.somesite.com | tee file.txt
The current accepted alternative involves running nmap twice which is a horrible idea.
You'd be better off running it once to file and then outputting the file.
nmap www.somesite.com > file.txt; cat file.txt
Oli
  • 299,380
That is exactly what tee is for. Why do you not want to use that?
An alternative might be to capture the output, and echo it twice:
output=$(nmap localhost)
echo "$output"
echo "$output" > somefile.txt
However, in the special case of nmap, you can take advantage of it's output option -ox :
      OUTPUT:
         -oN/-oX/-oS/-oG <file>: Output scan in normal, XML, s|<rIpt kIddi3,
            and Grepable format, respectively, to the given filename.
For example:
nmap -oN somefile.txt localhost
Seems to do exactly what you want: output to the terminal and also write to file.
mivk
  • 5,811
-1
It is not possible to have command line view and redirect process at the same time
But you can use the following command to use both the process in sequence
nmap www.somesite.com && nmap www.somesite.com > file.txt
First it will execute the command in terminal and then it will save the output as a file
Hope this helps!
BDRSuite
  • 3,196
  • 13
