-1
I recently installed Ubuntu on a new hard drive. I did not perform any partitioning operations during installation. After the installation and upgrade, I tried to partition the drive in which Ubuntu was installed.
  • Partition: /dev/sda2
  • File System: ext4
  • Mount Point: /
I am not able to create another partition from this one. Is it possible to do it or should I have to live with one BIG partition?
The option to resize this partition is greyed out.
What happens if I try to unmount this partition?
Zanna
  • 72,312
You are doing this using fdisk command you can do major operation with disk-drive
For a step-by-step guide refer to this link: How to use fdisk to manage partitions on Linux
Lorenz Keel
  • 9,511
Check the link, which will help you to resize the drive partition and to create an extended partition. From the resized partition you can create a primary or an extended partition:
Eliah Kagan
  • 119,640
BDRSuite
  • 3,196
  • 13
What you are trying to do is to shrink the running system partition of Ubuntu.
That is like to ask a surgeon to give himself a double bypass... ;-)
Boot the Ubuntu Live CD or the gparted live CD and then repartition!
Fabby
  • 35,017
