I'm using university PC which is Lenovo that came with Windows 8. I want to install Ubuntu to it. I've backed the data up, made extended partition, and installed Ubuntu. I have done this before to other PC and it went good. But not this time. This time after I installed it, Grub was not detecting Windows 8, so I tried to use Boot Repair. It didn't work. I've tried everything, but it just doesn't work. Boot Repair always showed different error prompt.
Can I just start over by installing new Ubuntu? Will that work? To make clear: I don't know what UEFI is, is that relevant to the installation process (I installed Ubuntu by old fashioned way, same with Windows 7)?
Please help...
Zyoo
  • 101
It sounds like you need to run update-grub from within Ubuntu, and may need to install/check os-prober
See this A. for a little more info, and an option to manually edit the grub.cfg config file https://askubuntu.com/a/12127/129271
  • After reading updated comments, it sounds like Ubuntu may not be installed correctly after all, so this may not apply...
Xen2050
  • 8,943
