I can’t get the scroll bar to show on this system. I can just about see it, but it’s hard to click on it to move it. How can I fix this?
TRiG
  • 2,006
I think your problem wasn't related to overlay scrollbars, but just in case it was:
For a normal scrollbar:
gsettings set com.canonical.desktop.interface scrollbar-mode normal
To revert to the default scrollbar:
gsettings set com.canonical.desktop.interface scrollbar-mode overlay-auto
(I have Lubuntu 14.04 and it works for me :) )
muru
  • 207,228
Rabbit
  • 792
It sounds like you are using a netbook with a small screen. If that is the case, merely move the window by using Alt and a left click. That will enable you to see the whole window. I have been living with windows that do not fit ever since installing Lubuntu on my netbook. Some applications fit or adapt to the smaller screen other applications do not.
Rex
  • 1,737
As you are asking about Lubuntu, which I'm only somewhat familiar with, I can't be certain it's not particular to that OS, but it seems to me that if placing your mouse at the far right hasn't made one appear, and you don't see one already, that could be that your screen size is mismatched to your monitor and you simply cannot see it.
Screen size mismatches rarely seem to occur in laptops, I most often see it on exotic external displays, projection display monitors and very small netbooks.
If you are using an external display (not a laptop), please press the auto-adjust button on the monitor if it has one.
Another option is to go into settings - displays and see if selecting other resolutions will cause the screen image to fit your monitor properly.
gyropyge
  • 2,568
