64
I made a mistake in the username at the time of installation. So I changed the name of the user after logging in by creating a guest account with SUDO rights. But when I checked the list of users using ls /home command I am not seeing the new name for the user instead Old name is appearing. But I use the new name to login.
Is it like I need to change the name inside Home directory separately? Also , if there is any other changes needs to be done .. ?
Procedure to rename or change username in Ubuntu:
If running as the user to be modified, logout first, then open a console:
Press Ctrl+Alt+F1
Otherwise, simply open a new Terminal:
Press Ctrl+Alt+T
And run:
exec sudo -i
killall -u [oldname]
id [oldname]
usermod -l [newname] [oldname]
groupmod -n [newname] [oldname]
usermod -d /home/[newname] -m [newname]
usermod -c "[full name (new)]" [newname]
id [newname]
Example:
sudo -i
killall -u belaje
id belaje
uid=1000(belaje) gid=1000(belaje) groups=1000(belaje),4(adm),24(cdrom),27(sudo),30(dip),46(plugdev),109(lpadmin),127(sambashare)
usermod -l  balaja belaje
groupmod -n balaja belaje
usermod -d /home/balaja -m  balaja
usermod -c "Bala Jagannathan" balaja
id balaja
Whenever you want to get back from console version to graphical version:
Press Ctrl+Alt+F7
Stachu
  • 103
kyodake
  • 17,808
23
on the server this worked for me:
sudo usermod -md /home/NewHome -l NewName OldName
sudo groupmod -n NewGroupName OldGroupName
This renames the user and its group and also the home folder.
wbloos
  • 341
This works, but a lot of the apps will break because they specifically call for the /home/oldusername; many individual software authors don't use variables to call their configs, they directly specify oldusername not $HOME. Chrome, GTK and firefox break like this. Don't forget your keyrings will have the old credentials as well... I'm not sure how to back those up.... maybe export them?
So, I end up doing the following to change username - man i wish i knew an easier way.
  • as olduser, sign in to chrome and firefox to sync out the settings
  • using users and groups in Settings, create user killmenow with pass of same, make him admin, reboot and log in as killmenow.
  • open terminal, riun sudo i, then mkdir /home/newusername and making it the same uid:gid as the oldusername
  • Move usercreatedfiles.xyz, Desktop, Downloads, and other dirs containing created files like docs, pics, music, movies, etc in /home/oldusername/ to /home/newusername.
  • Find out any specific apps with particular settings... Helpful to pay attention here :) user will likely bean you with a phonebook if you lose their files ;)
  • vi /etc/passwd and /etc/group to reference newusername and /home/newusername
  • passwd newusername and enter a temporary password twice reboot and log in as newusername, password being what you entered in the previous point.
  • delete killmenow using "users and groups" in Settings.
wait until some time passes before deleting /home/oldusername - in case you missed important stuff... or move it to /home/newusername/Downloads and tell them
mv /home/oldusername /home/newusername/Downloads/oldusername-backup
muru
  • 207,228
-3
Please try the below to change the user name in home directory,
usermod -d /home/newHomeDir -m newUsername
Hope this helps !
Pilot6
  • 92,041
BDRSuite
  • 3,196
  • 13
