I try to make an ethernet network of 2 Computers, both with Ubuntu. I am using cross cable. I tried to connect them as shown here. How to network two Ubuntu computers using ethernet (without a router)? When I open Browse Network folder(to share files) on both computers, the computers are not shown. Ping shows 64 bytes from 10.0.0.2: icmp_seq=1 ttl=128 time=0.457 ms multiple entrys(doesnt stop) System monitor on the first showed a transmission of 600MB, on the other one some kb in up and download.
Asked
Active
Viewed 393 times
A way to share folders
In each of the computers:
Open a terminal,
Press Ctrl+Alt+T
And install Samba running:
sudo -i
apt-get update
apt-get install samba samba-common samba-common-bin samba-vfs-modules smbclient
Set a password for each user in Samba
sudo -i
smbpasswd -a <user_one>
smbpasswd -a <user_two>
Create a directory to be shared, suppose /home/user/Share
sudo -i
mkdir /home/<user_name>/Share
Edit the file /etc/samba/smb.conf
sudo -i
nano//etc/samba/smb.conf
In the open file, add this to the very end of the file:
[Share]
path = /home/<user_name>/Share
available = yes
valid users = <user_one>, <user_two>
read only = no
browseable = yes
public = yes
writable = yes
Ctrl + O, save file. Ctrl + X, close nano.
To access the network share use:
your username and password through the path:
smb://<HOST_IP>/home/<user_name>/Share
kyodake
- 17,808
