I have Installed Ruby On Rails of version 2.1.3p242 on my system. But I can't findout the ruby command line. I have searched but not found.
I have try to to check through
man ruby : Show some details
man rail : "See 'man 7 undocumented' for help when manual pages are not available."
May anybody help me to open the Ruby cmd line.
Nishant
  • 211
There are two ways of interactively using ruby on the command line (like running python or nodejs, for example):
Simply run ruby:
$ ruby
print "hello world\n"
Then press CtrlD. You will see:
hello world
The easier way is Interactive Ruby (irb):
$ irb
irb(main):001:0> print "hello\n"
hello
=> nil
irb(main):002:0>
muru
  • 207,228
If you want a "Ruby command line" then you want irb
The command ruby is the non-command-line version. You can use that from the command line in several ways(*), but it is not a command line in itself.
As you didn't find irb, I guess you may not know about the command apropos The word means "pertinent information about" and typing
apropos ruby
will list a number of ruby-related things, including irb.
The argument for the command man usually must match the command or whatever exactly, so
man rail
would not find a manual page, even if there was one, man rails normally would, but I believe there is no rails man-page and you have to refer to the Ruby documentation for that.
(*) The usual Unix methods, e.e.:
  • As shown in the answer above.
  • echo 'print "hello world\n"' | ruby
  • ruby < my-ruby-prob.rb
  • The 'hereis' and 'shebang (#!) methods
Gordon
  • 613
