I am unable to install git on my ubuntu 12.10 system. I followed-
sudo add-apt-repository ppa:git-core/ppa
sudo apt-get update
sudo apt-get install git-core
sudo apt-get update gives me the error-
Err http://security.ubuntu.com quantal-security/main amd64 Packages
  404  Not Found
Err http://security.ubuntu.com quantal-security/restricted amd64 Packages
  404  Not Found
Err http://security.ubuntu.com quantal-security/universe amd64 Packages
  404  Not Found
Err http://security.ubuntu.com quantal-security/multiverse amd64 Packages
  404  Not Found
Err http://archive.ubuntu.com quantal-updates/main amd64 Packages
  404  Not Found
Err http://archive.ubuntu.com quantal-updates/restricted amd64 Packages
  404  Not Found
Err http://archive.ubuntu.com quantal-updates/universe amd64 Packages
  404  Not Found
Err http://archive.ubuntu.com quantal-updates/multiverse amd64 Packages
  404  Not Found
Err http://archive.ubuntu.com quantal/main amd64 Packages
  404  Not Found
Err http://archive.ubuntu.com quantal/restricted amd64 Packages
  404  Not Found
Err http://archive.ubuntu.com quantal/universe amd64 Packages
  404  Not Found
Err http://archive.ubuntu.com quantal/multiverse amd64 Packages
  404  Not Found
Then some failed to fetch errors and finally-
E: Some index files failed to download. They have been ignored, or old ones used instead.
When I run sudo apt-get install git, I get-
Building dependency tree
The following extra packages will be installed:
  git-man liberror-perl
Suggested packages:
  git-daemon-run git-daemon-sysvinit git-doc git-el git-arch git-cvs git-svn
  git-email git-gui gitk gitweb
The following NEW packages will be installed:
  git git-man liberror-perl
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 6,800 kB/6,824 kB of archives.
After this operation, 15.3 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
  liberror-perl git-man git
Install these packages without verification [y/N]? y
Err http://archive.ubuntu.com/ubuntu/ quantal/main git-man all 1:1.7.10.4-1ubuntu1
  404  Not Found
Err http://archive.ubuntu.com/ubuntu/ quantal/main git amd64 1:1.7.10.4-1ubuntu1
  404  Not Found
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/git/git-man_1.7.10.4-1ubuntu1_all.deb  404  Not Found
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/git/git_1.7.10.4-1ubuntu1_amd64.deb  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
I have just set up ubuntu and this is the first I tried installing. Please help.
Ubuntu 12.10 has reached End Of Life and is no longer supported.
You use digitalocean mirrors,
edit your /etc/apt/source.list to:
deb http://archive.ubuntu.com/ubuntu precise main
deb http://archive.ubuntu.com/ubuntu precise-updates main
deb http://security.ubuntu.com/ubuntu precise-security main universe
deb http://archive.ubuntu.com/ubuntu precise universe
deb http://archive.ubuntu.com/ubuntu precise-updates universe
and then execute
do-release-upgrade
This is just a temporary workaround for those who haven't upgraded yet, but still its strongly recommended your system to latest version ASAP, to avail all security updates.
BDRSuite
  • 3,196
  • 13
