I have a new Lenovo Yoga 3 Pro but I can't install Ubuntu 14.04 on it.
I tried working through the instructions for the Yoga 2, but after editing the grub boot line and pressing enter, the screen goes blank and stays blank. But the power is on. I wonder if perhaps the system is waiting for me to do something but I can't see it because the screen is blank. I did add the acpi_backlight=vendor bit to the boot line (before quiet) so that is probably not the issue....
I have to hold down the power button for ~20 seconds to get the power to turn off and then I can turn it back on and repeat the process, but I never get past that point. Any ideas?
You should install Ubuntu 14.10 instead of 14.04. See my guide.
longsleep
  • 2,305
  • 16
  • 13
No need to edit Grub. Insert USB boot drive. Push button on right side for boot menu. Change to legacy in BIOS. Change to boot USB drive and install. Wireless will not work. Go here for solution: Ubuntu on Lenovo Yoga 3 Pro Touchpad and Touch screen will not work. Upgrade to kernel 3.18 to fix this but wireless will again not work and their is no solution presently.
