*display
description: VGAcompatible controller
product: RS780M [MobilityRadeonHD 3200]
vendor: Hynix Semiconductor Hyundai Electronics
physical ID: 5
bus info: pci@0000:01:05:0
version: 00
width: 32 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver radeon latency=00
resources: irq:18 memory: 89999999-8fffffff ioport: 5000 (size=256) memory: 94300000-94300000-9430ffff memory94200000-942fffff
Hello again, I tried everything, but nothing worked. I even tried looking for more fglrx files after reading the pages you linked to. I found two and deleted them then tried installing the driver again, but got a huge list of unmet dependencies "livetex".... 2013 version needed.... 2009 about to be installed".
The only way I think I can get it to work is by reinstalling 12.04 from disk but my DVD player doesn't work. Can't boot up with USB because I lost my bios password. "Great". I still like Ubuntu but next time instead of reading ubuntu 'release notes' before upgrading, I think I will google with the websites that you linked to and read the compatibility pages that I found the other day.
You have been a great help and I give you my thanks! I think your suggestions should have fixed the problem so I am going to mark the question as "answered". I think there was just something a little off with my installation. I hope you have a great weekend and a great Holiday season!
Perform the following:
  1. Ctrl + Alt + F3.
  2. Login as your user.
  3. sudo service lightdm stop
  4. startx
Please post the results in your original question. I'll update this answer depending on your output.
Update
As per your comments, now that we've verified your terminal is working we need to install some tools, you may already have these:
  1. sudo apt-get install lshw pciutils nano
Now that we have the tools, post the output of lshw -class display and nano -w /var/log/XOrg.0.log
Update 2
Knowing your Laptop model is a Compaq 615 AMD Athlon X2 Dual Core QL-66 leads me to the official tech spec document, and the following Linux Mint Post:
ATI Mobility Radeon HD 3200 Proprietary Driver for Linux Mint 12
The big red note on that link is what you're experiencing.
Explanation
During the distribution upgrade process your kernel was updated to a newer kernel. Doing so, the upgrade process was unable to use the default radeon driver for your cards, because you had the frglx driver installed. Since your old driver is not compatible with the newer kernel, we have 2 options:
  1. Downgrade to the kernel your frglx driver works with, or
  2. Replace the frglx driver with the default driver and then manually install the older frglx driver.
I personally prefer option 2. So without further ado, I present the
Resolution
  1. From the Command Prompt, issue a:
    sudo apt-get remove --purge xorg-driver-fglrx fglrx* sudo apt-get install --reinstall libgl1-mesa-glx:amd64 libgl1-mesa-dri:amd64 libgl1-mesa-glx:i386 libgl1-mesa-dri:i386 xserver-xorg-core
    sudo dpkg-reconfigure xserver-xorg
  2. sudo reboot
This should get lightdm started so you have a GUI, because we need a browser to go to the Legacy AMD Driver Download Page and Download Legacy Version 13.1 for ATI Radeon Series 3xxx. If something failed, and you have no GUI, issue: sudo apt-get install wget && wget http://www2.ati.com/drivers/legacy/amd-driver-installer-catalyst-13.1-legacy-linux-x86.x86_64.zip
Save this for later, as this driver only works for kernels where the version is <= 3.4.0. Since the Ubuntu Kernel is now >= 3.13.0, we will run into the same issue again. This leaves us 2 options:
  1. Manually Download the last available release of the 3.4 Kernel for Ubuntu Manually. If you choose this option Download and install every .deb file in that directory, along with the patches. Note: Using this option prevents you from upgrading to any kernel above Debian 3.4.105 during system updates! In exchange for a permanently downgraded kernel, you may now install the legacy frglxdriverby unzipping the file above. Be sure to use chmod +x on the extracted file.
  2. Install the in-kernel Radeon Driver. This was done in step 1 of the Resolution Section. You can now delete /etc/X11/xorg.conf if you still have one. In exchange for the in-kernel driver, you can continue upgrading to newer kernels as they come out.
References
X Troubleshooting - Ubuntu Wiki - Purging frglx
The definitive guide to proprietary AMD graphics drivers
Ubuntu Wiki - Radeon Driver
eyoung100
  • 975
