I have been trying to get VirtualBox to enable my USB devices to attach them to the guest OS. However, when trying to attach them while the guest is running all devices are greyed out. Also device filters are not working.
I am pretty sure that this is a rights problem because it works perfectly when starting VirtualBox as root.
Here is my current setup:
  • Host OS: Ubuntu 14.04.1 (64bit)
  • Guest OS: Windows 7 (64bit)
  • VirtualBox 4.3.20 r96996
  • Guest additions are installed
  • Package was downloaded from virtualbox.org
And this is what I tried so far:
Slowly, I am running out of ideas. Most other posts I read about this problem were solved by adding the user to the vboxusers group. However, this did not fix it for me.
I think it might be possible that whatever resource needs to be accessed to handle USB devices is for some reason not accessible for the vboxusers group. I do not know which resource this is so I am unable to check.
Could you point me in the right direction to investigate this further?
Chris
  • 357
I had the same problem as you. The group virtualboxusers and so on were correct.
After some search, it turns out that the kernel module did not correspond to the right version of my kernel (3.13.0-65-generic) and to my version of virtualbox (4.3).
The command
sudo dpkg-reconfigure virtualbox-4.3
solved my problem.
Hope it will help you if the question is still problem still persists.
Mathieu
  • 41
I'm not sure if this will work, but these are the files owned by vbosusers on my machine, where USB is working right under Virtual Box.
sudo find / -group vboxusers
/dev/vboxusb
/dev/vboxusb/002
/dev/vboxusb/002/003
/dev/vboxusb/001
/dev/vboxusb/001/004
In another machine it looks like this
/dev/vboxusb
So it looks like only ownership of /dev/vboxusb matters.
Hope that it helps.
Javier Rivera
  • 35,434
