I am using Ubuntu 14.04 and it seems that these packages are not installed. How can I install them as I need them for an application ?
Err http://ppa.launchpad.net trusty/main i386 Packages
404 Not Found
pg19
It looks like you added the PPA using a wrong procedure. Uninstall the last PPA you installed by using the reverse procedure you used to install it and add it again using:
sudo add-apt-repository ppa:TheUser/TheNameOfThePPA
sudo apt-get update
and only then do a:
sudo apt-get install ThePackageName
And the above commands would have been even more helpful if you would have given:
  • the name of the package instead of "these"
  • the procedure you used to install the package
Fabby
  • 35,017
