I want to create a text file which will add each command I am going to run on the terminal as a new line entry in the text file. i.e., I need to keep a record of what are the things I'm doing in the terminal. Further if I can keep a record of outputs I'm getting in the terminal, along with the inputs in the terminal, as a text file, it will be much better.
Each time I forget a command I have to search again in the Internet for the command.
Can I can make a file like above?
αғsнιη
  • 36,350
Praveen
  • 1,025
You can use script to make typescript of terminal session. It will record all the inputs and output to a file. To start recording type in terminal,
$ script
Go on doing your regular job. To end the recording use Ctrl+D. All the typescript will be saved in the file typescript located at the directory where you opened the terminal.
To save all the log in your desired file, use
$ script /path/to/mylogfile.txt
Usually script comes with default Ubuntu installation.
sourav c.
  • 46,120
Comment by tim will solve the first part of the question.
Running history on terminal shows the commands previously ran on terminal.
Running history >> file.txt on terminal creates file.txt in home directory which has as entry the commands previously ran on terminal.
Praveen
  • 1,025
