I'm having troubles with the communication between a NXT-Lego device and a Notebook with USB 3.0 port.
I affirm that the problem is the USB 3.0 - driver, because this same device with another Notebook very similar, a pretty older model with only USB 2.0 works.
Notebook, System info: 2 port USB 2.0
1 port USB 3.0, SO: Ubuntu 12.04
kernel: 3.8.0-33-generic
My approach to resolve this communication problem, is force the notebook to see all the usb pot as USB 2.0.
Now the SO load for all usb port, xhci_hcd driver, but I want SO load ehci_pci (USB 2.0) driver.
How i can achieve that ? Another way than by BIOS, because this notebook BIOS hasn't this configuration option.
Thanks
gduarte
  • 51
This works for me: lspci -nn | grep USB | cut -d '[' -f3 | cut -d ']' -f1 \ | xargs -I@ setpci -H1 -d @ d0.l=0
sudo is required.
With that comamnd you change your 3.0 ports to 2.0. More info here.
user80390
  • 111
The solution for me to a similar sounding problem was to simply use a 2.o Hub in between. I'm not sure this would have solved the OP's issue ( 4.5 years ago ) but it's an easy thing to try.
JJones
  • 151
