When I upgraded to Ubuntu 14.04, apparently my kernel was supposed to upgrade from 3.11 to 3.13. Unfortunately, the kernel upgrade did not complete. As a result, I have several files for 3.13, but am still running 3.11. I've decided the best thing for me to do is to complete the kernel upgrade.
Specifically, when I look at the linux packages I have installed, I see:
me@Bedrock1:~/Downloads/cudaDownloads$ dpkg -l | grep "linux-" | cut -d " " -f 3
gcc-4.8-powerpc-linux-gnu-base
linux-firmware
linux-headers-3.13.0-29
linux-headers-3.13.0-29-generic
linux-headers-3.13.0-30
linux-headers-3.13.0-30-generic
linux-headers-3.13.0-32
linux-headers-3.13.0-32-generic
linux-headers-3.13.0-34
linux-headers-3.13.0-34-generic
linux-headers-3.13.0-35
linux-headers-3.13.0-35-generic
linux-headers-3.13.0-36
linux-headers-3.13.0-36-generic
linux-headers-3.13.0-37
linux-headers-3.13.0-37-generic
linux-headers-3.13.0-39
linux-headers-3.13.0-39-generic
linux-headers-generic
linux-image-3.11.0-23-generic
linux-image-3.8.0-33-generic
linux-image-extra-3.11.0-23-generic
linux-image-extra-3.8.0-33-generic
linux-libc-dev:amd64
linux-sound-base
linux-source
linux-source-3.13.0
syslinux-common
syslinux-legacy
and, when I look in my boot directory, I see:
me@Bedrock1:~$ ls /boot
abi-3.11.0-23-generic         memtest86+.bin
abi-3.8.0-33-generic          memtest86+.elf
config-3.11.0-23-generic      memtest86+_multiboot.bin
config-3.8.0-33-generic       System.map-3.11.0-23-generic
grub                          System.map-3.8.0-33-generic
initrd.img-3.11.0-23-generic  vmlinuz-3.11.0-23-generic
initrd.img-3.8.0-33-generic   vmlinuz-3.8.0-33-generic
It looks as though I can use apt-get/synaptic to install linux-image-3.13 and linux-image-extra-3.13, but I can't find downloads for any of the files in my /boot directory. Is there something obvious I'm missing here?
Should I expect installation of the correct packages to update GRUB files as necessary, or will I need to read up on that before I start booting into the 3.13 kernel?
Are there any other files I should be checking for?
Is there an obvious reason why my kernel didn't manage to update completely to 3.13? If so, do I need to compensate for it?
user1245262
  • 273
Currently on Ubuntu 14.04, my kernel version is 3.16.0-25. Try installing this version if you want the latest one.
Have you tried simply the following commands? The first one checks the updates and the second one installs them ?
sudo apt update
sudo apt upgrade
What is the output?
jhecn
Some installer may prompt for separate boot partition, and if that is small size then it can become full and fail to build new kernel/initramfs. Check this with df?
