here's my computer spec:
- Ubuntu 14.04 LTS
- 64 bit
- always do package updates everyday
I'm installing teamviewer 10 by using gdebi similar to this link: team viewer error dependency install method
then there are many errors occur on log file, so I chmod all exe files in /opt/teamviewer/tv_bin$ and hope it's ready for connection
but then I get something like this (on logfile, wine):
fixme:service:scmdatabase_autostart_services Auto-start service L"MountMgr" failed to start: 2
fixme:service:scmdatabase_autostart_services Auto-start service L"PlugPlay" failed to start: 2
fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
fixme:ole:CoInitializeSecurity ((nil),-1,(nil),(nil),0,3,(nil),0,(nil)) - stub!
fixme:heap:HeapSetInformation (nil) 1 (nil) 0
fixme:process:SetProcessDEPPolicy (3): stub
fixme:ver:GetCurrentPackageId (0x32f8e4 (nil)): stub
fixme:process:SetProcessShutdownParameters (00000100, 00000000): partial stub.
fixme:win:EnumDisplayDevicesW ((null),0,0x32d510,0x00000000), stub!
fixme:win:EnumDisplayDevicesW (L"\\\\.\\DISPLAY1",0,0x32d858,0x00000000), stub!
fixme:win:EnumDisplayDevicesW ((null),1,0x32d510,0x00000000), stub!
fixme:module:load_library unsupported flag(s) used (flags: 0x00000060)
fixme:resource:GetGuiResources (0xffffffff,0): stub
WARNING: QApplication was not created in the main() thread.
Unable to load library icui18n "Cannot load library icui18n: (icui18n: cannot open shared object file: No such file or directory)"
fixme:ntdll:NtQueryInformationToken QueryInformationToken( ..., TokenElevation, ...) semi-stub
fixme:winhttp:WinHttpDetectAutoProxyConfigUrl discovery via DHCP not supported
fixme:bitmap:CreateBitmapIndirect planes = 0
fixme:msg:ChangeWindowMessageFilter 233 00000001
fixme:msg:ChangeWindowMessageFilter 4a 00000001
fixme:msg:ChangeWindowMessageFilter 407 00000001
fixme:msg:ChangeWindowMessageFilter 49 00000001
fixme:wtsapi:WTSRegisterSessionNotification Stub 0x1007a 0x00000000
err:ole:marshal_object couldn't get IPSFactory buffer for interface {00000131-0000-0000-c000-000000000046}
err:ole:marshal_object couldn't get IPSFactory buffer for interface {00000122-0000-0000-c000-000000000046}
err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hres=0x80040155
err:ole:CoMarshalInterface Failed to marshal the interface {00000122-0000-0000-c000-000000000046}, 80040155
fixme:msg:ChangeWindowMessageFilter c058 00000001
fixme:nls:GetGeoInfoW -1 4 0x32fc44 3 0
err:secur32:SECUR32_initSchannelSP TLS library not found, SSL connections will fail
err:winediag:SECUR32_initNTLMSP ntlm_auth was not found or is outdated. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
it's still not ready for connection.
any idea how to solve this?
I've tried to uninstall and install it again using teamviewer 9, same problem occurs.
