Okay, so I want add a command to my Desktop (Or any convenient location), and whenever I run it I want it to clone the HTML5 boilerplate.
$ git clone git://github.com/paulirish/html5-boilerplate.git
And I'm tired of typing it out all the time. So how could I store my commands in a file?.
enzotib
  • 96,093
Open your ~/.bashrc and put this at the end:
alias boil='git clone git://github.com/paulirish/html5-boilerplate.git'
or alternatively, this
boil() {
From now on, in every new terminal you can use the command boil as an alternative to your long command.
The second version is to prefer, because is more flexible being able to accept and manage parameter, for example if you define
boil() {
  [[ -z "$1" ]] && set "github.com"
  git clone git://"$1"/paulirish/html5-boilerplate.git
you can easily change server, if there are mirror.
# without a parameter, the function will use a default
boil
# override the default providing explicitly a server parameter
boil othergit.com
It is only an example, your fantasy surely will think up something more useful.
Obviously you can add as many functions as you need.
enzotib
  • 96,093
-3
Why not create a document with that command, and every time you wish to use it you can simply copy and paste it into the terminal.
scouser73
  • 4,344
