I am trying to install current stable version 0.12.1, but it only installs 0.9.9.
Any chance to install latest version with apt-get install? It seems that 0.9.9 is very old :(
- 20,535
- 462
In Ubuntu 16.04 and later wkhtmltopdf 0.12.2+ can be installed from the default Ubuntu repositories.
In Ubuntu 14.04, open the terminal and type:
sudo add-apt-repository ppa:ecometrica/servers
sudo apt-get update
sudo apt-get install wkhtmltopdf
In Ubuntu 12.04, open the terminal and type:
sudo add-apt-repository ppa:pov/wkhtmltopdf
sudo apt-get update
and one step after this is to reboot the server or else you will get the error: wkhtmltopdf: cannot connect to X server .
- 122,292
- 133
- 301
- 332
Steps:
At first install xvfb serwer:
sudo apt-get install xvfbGet needed version of wkhtmltopdf from http://wkhtmltopdf.org/downloads.html.
For Ubuntu 14.04 64-bit:
wget http://download.gna.org/wkhtmltopdf/0.12/0.12.2.1/wkhtmltox-0.12.2.1_linux-trusty-amd64.debInstall wkhtmltopdf:
sudo dpkg -i wkhtmltox-0.12.2.1_linux-trusty-amd64.debInstall dependency (if needed):
sudo apt-get -f installCreate symblic link in
/usr/local/bin/:echo 'exec xvfb-run -a -s "-screen 0 640x480x16" wkhtmltopdf "$@"' | sudo tee /usr/local/bin/wkhtmltopdf.sh >/dev/null sudo chmod a+x /usr/local/bin/wkhtmltopdf.sh
- 36,890
- 56
- 97
- 151
- 521
I used the following on Ubuntu 14.04.5 LTS
wget http://download.gna.org/wkhtmltopdf/0.12/0.12.2/wkhtmltox-0.12.2_linux-trusty-amd64.deb
sudo apt-get install libxrender1 xfonts-utils xfonts-base xfonts-75dpi libfontenc1 x11-common xfonts-encodings libxfont1 fontconfig
sudo dpkg -i wkhtmltox-0.12.2_linux-trusty-amd64.deb
sudo reboot now
Note: this is version 0.12.2! So you don't have to deal with installing xvfb since you're probably not running X as it's a server.
If it fails at sudo dpkg -i wkhtmltox-0.12.2_linux-trusty-amd64.deb then proceed with sudo apt get install -f to install with dependencies.
- 119
To install wkhtmltopdf 0.12.5 on ubuntu 16.04, try this,
Wkhtmltopdf version 0.12.5 is recommended for odoo 12.
wget https://github.com/wkhtmltopdf/wkhtmltopdf/releases/download/0.12.5/wkhtmltox_0.12.5-1.trusty_amd64.debInstall the package using DPKG.
sudo dpkg -i wkhtmltox_0.12.5-1.trusty_amd64.debThis will install all dependencies.
sudo apt -f install
- 18,154
Try this Solution :
Download the deb archive and install using DPKG.
sudo dpkg -i wkhtmltox-0.12.1_linux-trusty-amd64.debsudo ln -s /usr/local/bin/wkhtmltopdf /usr/binsudo ln -s /usr/local/bin/wkhtmltoimage /usr/bin
- 18,154
- 111
After trying the below command, It worked for me
cd ~
yum install -y xorg-x11-fonts-75dpi xorg-x11-fonts-Type1 openssl git-core fontconfig
wget https://downloads.wkhtmltopdf.org/0.12/0.12.4/wkhtmltox-0.12.4_linux-generic-amd64.tar.xz
tar xvf wkhtmltox-0.12.4_linux-generic-amd64.tar.xz
mv wkhtmltox/bin/wkhtmlto* /usr/bin
- 615
