I'm only asking this question because any other answer I found online to this problem didn't help me resolve it.
Basically I updated my Ubuntu 14.04 system last night and it asked me to restart my system. When I restarted it and logged in to my admin account the Unity interface didn't load. I could only see my background and Ubuntu 14.04 written in the bottom right corner of the screen. No shortcuts work like Alt+Ctrl+t to open the terminal, the mouse right click doesn't work either. I can only access the terminal with Alt+Ctrl+F1. I restarted the system several times and it was the same every time. I can, however, log in to another account which is not an administrator account, and that's what I'm using right now, but I don't have access to all my files from my admin account which I normally use.
I tried a number of solutions that people said worked for them in similar circumstances but none of them worked. I even installed gnome to see if that will help, but it didn't. Again I could only log in to the other non-admin account which displayed gnome without a problem, but the admin account didn't move past the background after login.
I even tried booting to another kernel in advanced options but that didn't work either.
I found the following solutions online which I tried but none of them worked:
sudo apt-get install unity-tweak-tool
unity-tweak-tool --reset-unity
Another one was:
sudo apt-get install compizconfig-settings-manager
export DISPLAY=:0
ccsm
Also this one:
sudo apt-get update --fix-missing
And this one:
sudo apt-get purge lightdm
sudo apt-get update
sudo apt-get install lightdm
dpkg-reconfigure lightdm
sudo shutdown
None of these worked. Can anyone please help me with this?
muru
  • 207,228
As you have one user that works in the GUI and an admin that works in console mode, you have all you need to recover your system without re-installing it.
Log into the Admin account using Ctrl+Alt+F1 and type:
sudo adduser admin-new
Enter all info and then type:
sudo adduser admin-new adm
sudo adduser admin-new cdrom
sudo adduser admin-new sudo
sudo adduser admin-new dip
sudo adduser admin-new plugdev
sudo adduser admin-new lpadmin
sudo adduser admin-new sambashare
log off and log on as admin-new using the GUI (if this doesn't work, report back here)
Open a terminal with Ctrl+Alt+T and type:
Warning! Do not try to be smart and do a cp --recursive /home/admin-old/* /home/admin-new/ as this will copy the error(s) you have in your current user settings!!!
cp --recursive --no-dereference /home/admin-old/Documents/* /home/admin-new/Documents
cp --recursive --no-dereference /home/admin-old/Downloads/* /home/admin-new/Downloads
cp --recursive --no-dereference /home/admin-old/Pictures/*  /home/admin-new/Pictures
cp --recursive --no-dereference /home/admin-old/Templates/* /home/admin-new/Templates
cp --recursive --no-dereference /home/admin-old/Desktop/*   /home/admin-new/Desktop
cp --recursive --no-dereference /home/admin-old/Music/*     /home/admin-new/Music
cp --recursive --no-dereference /home/admin-old/Public/*    /home/admin-new/Public
cp --recursive --no-dereference /home/admin-old/Videos/*    /home/admin-new/Videos
(Leave out the stuff you don't really need any more like the old Downloads directory or the Templates or …)
You now have 99% of all your stuff back! (if you do not have enough space to do the above all together, delete the original in-between copy commands)
If you want to copy any additional directories beyond those above, make a full system backup first because one of the directories you didn't copy contains the error.
Now do a: deluser --remove-home admin-old
A.B.
  • 92,125
Fabby
  • 35,017
Instead of getting rid of all settings by coping only the data files to a new user, there is one more option to try first:
rm /home/{affected user}/.config/dconf/user
sudo service lightdm restart
This gets rid of the unity-related settings only, and for most problems like this, it is enough to get you back to a working state. It worked for me and saved hours of work compared to the other solution.
Source
A.B.
  • 92,125
Edgar
  • 773
