I am using Ubuntu 14.04, and run a partial upgrade via Update Manager.
This resulted in removing VLC.
I've tried reinstalling using sudo apt-get install vlc but got this error:
distribution that some required packages have not yet been created or
been moved out of Incoming. The following information may help to
resolve the situation:
The following packages have unmet dependencies: vlc : Depends:
vlc-nox (= 3.0.0~~git20141202+r58827+31~ubuntu14.04.1) but it is not
going to be installed
Depends: libavutil53 (>= 6:9.1-1) but it is not installable
Recommends: vlc-plugin-notify (= 3.0.0~~git20141202+r58827+31~ubuntu14.04.1) but it is not going to be installed
Recommends: vlc-plugin-samba (= 3.0.0~~git20141202+r58827+31~ubuntu14.04.1) but it is not going to be installed E: Unable to correct problems, you have held broken
packages.
I've tried the solutions mentioned here (purging vlc) and here (adding the stable-daily ppa) but none of them worked, still getting the same error.
What can I do now?
Updates
- Tried
sudo apt-get install -fand then installing vlc, still the same results. Tried the solution from the other question, and after trying several suggestions with no succes, I selected the one that offered to install the most of the packages. VLC was installed but not properly, as I am getting this error now
VLC media player 3.0.0-git Vetinari (revision 3.0.0~~git20141202+r58827+31~ubuntu14.04.1) [000000000243c118] core libvlc error: No plugins found! Check your VLC installation.
