I'm looking for a PPA for Ruby 1.9.2 for Lucid Lynx, and I've noticed that there's a couple of them. Is it possible to determine which one is more commonly used, and therefore more likely to be error-free?
The important thing to remember is that anyone can register a PPA. The main question you need to ask yourself is do you trust the PPA's owner. The level of trust needed depends on the package and what you hope to do with it. I might trust a PPA for an indicator based on the recommendation of a blog that I follow, but I'd want to know a lot more about the PPA owner if I were looking to upgrade X on my desktop or Ruby on a production server.
You should look at the PPA's owner on Launchpad. Is it team maintainer? What else is the owner involved with? Is the owner involved with the software upstream? Is the owner an Ubuntu developer?
Remember when you add a PPA to your sources, the main concern isn't the installation of a single package, it's that you are more or less giving the PPA root access to your machine through the ability to push updates.
Though it works the other way as well. Is the owner still actively providing security updates? foo 1.0 in Lucid might be a bit old, but at least it is still receiving security updates. foo 1.2 from Joe Bob's PPA might be more recent, but if a security bug is found to affect both version is he going to provide an update? Check their Lauchpad profile to make sure they are at least active.
Here's a scary story. I was investigating a PPA to possibly recommend to you for getting Ruby 1.9.2 on Lucid. Unfortunately one seeming popular one I came across is run by an "open" team. Team membership confers upload right to the team's PPA. As it now stands, someone could potentially join the team and upload a compromised version of the software in the PPA at anytime.
- 37,702
First you check what is available in the official repositories.
- Go to http://packages.ubuntu.com/ and perform a search for
ruby. In the search options, trylucid,lucid-updates(only of Ruby had a security update) andlucid-backports(only for newer versions that have been packaged back for lucid).
I performed the search and found that there is only one version of Ruby available (in lucid), and it is version 4.2. When you mention version 1.9.2, do you refer to the ruby package or some companion package?
- 9,241
There are unofficial ones that people compile code to and stick up for anyone (brave enough) to use but the official and (probably better tested) version is the one in http://packages.ubuntu.com/ - which you can access via synaptic. I wouldn't touch the other PPAs for production systems.
The short answer seems to be that the only supported version of Ruby at the moment on Ubuntu is 1.8. Don;t touch 1.9.1 with a barge-poll if you're using Rails - there's even a message on the Rails homepage to that effect.
- 101
