I have a partition formated to btrfs and im willing to store there stuff that I don't use that often but which I need fast access from time to time (some dumps of my PS2 games for now) because I have read that btrfs can work wonders compressing data on the fly.
The thing is even when mounting this partition using the compress-force=zlib option I can't notice any compression work at all.
Currently my /etc/fstab file display the following info for the drive in question:
LABEL=Emu /mnt/Emu btrfs compress-force=zlib,nosuid,nodev,nofail,comment=x-gvfs-show 0 0
The drive mounts fine and data can be written and read back. But no compression work is done, not with old files nor with new ones.
So far I've tested it by doing the following:
$ sudo dd if=/dev/sda6 of='/mnt/Emu/dummy.txt' bs=1M count=1024
$ sudo btrfs fi sync /mnt/Emu
$ sudo du -h '/mnt/Emu/dummy.txt'
This generated a 1 GB file in said drive and told me the size of the file is indeed 1 GB so nothing has been compressed.
Also verified the size after using chattr +c on said dummy file and then defragmenting the file/drive by using btrfs fi defragment on them.
Any pointing?
My systems specs:
  • OS: Ubuntu 14.04 x86_64
  • Kernel: 3.13.0-40-generic
  • Btrfs: v3.12
eridani
  • 1,584
See Will btrfs automatically compress existing files when compression is enabled? on best practices compressing with btrfs:
  1. The command is btrfs fi defrag not btrfs fi sync
  2. it must be applied to file, btrfs fi defrag /mnt/Emu/dummy.txt not to dir
  3. how exactly do you decide it is not compressed? df is not showing proper sizes.
