I install Ubuntu 14.04, When i add:
sudo apt-get upgrade
I get this error:
root@:~# sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up udev (204-5ubuntu20.8) ...
* udev requires hotplug support, not started
...fail!
invoke-rc.d: initscript udev, action "restart" failed.
dpkg: error processing package udev (--configure):
subprocess installed post-installation script returned error exit status 1
udev
root@:~#
When i add:
sudo apt-get install curl
I get this error:
...fail!
udev
root@:~#
Anyone know how to fix this ?
Thanks.
