33
Hello fellow Ubuntu users,
I am trying to learn how to write modifications to Minecraft. In order to follow the tutorial I am using, I need to run a "gradlew". The command is as follows
./gradlew setupDecompWorkspace eclipse
This yields the following
ERROR: JAVA_HOME is set to an invalid directory: /usr/local/java/jdk1.8.0_20
Please set the JAVA_HOME variable in your environment to match the
location of your Java installation.
Obviously I don't know what to do or even what this means. Any help is much appreciated.
6 Answers6
54
Before running the command try entering:
export JAVA_HOME="path_to_java_home"
Where path_to_java_home is the folder where your bin/java is.
If java is properly installed you can find it's location, by using the command:
readlink -f $(which java)
Don't forget to remove bin/java from the end of the path while putting it into JAVA_HOME
28
To make it automatic on Linux/Ubuntu, add these lines at the end of your .bashrc:
JAVA_HOME=$(dirname $( readlink -f $(which java) ))
JAVA_HOME=$(realpath "$JAVA_HOME"/../)
export JAVA_HOME
This gets java executable, then climbs up a directory level
To designate the default java version/executable on Debian/Ubuntu, run this once:
sudo update-alternatives --config java
This builds up on previous answer by Andrew Onischuk (thanks!)
Get your Java path using the command
whereis java
The following is a possible output depending on your default Java version
java: /usr/bin/java /usr/share/java /usr/lib/jvm/jdk1.8.0_241/jre/bin/java
Maven need to pick the Java location (home) so you can export the Java path using the following command
export JAVA_HOME=/usr/lib/jvm/jdk1.8.0_241/jre
This will allow Maven to pick the java version and location in the /etc/environment file
Optionally you can add this in the /etc/environment manually using the following command
sudo nano /etc/environment
and edit the JAVA_HOME=/usr/lib/jvm/jdk1.8.0_241/jre/
Jose Mhlanga
  • 131
Try to edit /usr/bin/gradle
Comment the line "export JAVA_HOME=/usr/lib/jvm/default-java" with a #
this: #export JAVA_HOME=/usr/lib/jvm/default-java
Run with sudo
sudo ./gradlew setupDecompWorkspace eclipse
You are not a sudo doer for running this command
So Add sudo to it.
With Ubuntu, got the same issue with building a react native project.
# Replace this
export JAVA_HOME=/usr/lib/jvm/openjdk-17
by that
Seemed to do the trick, although I'm not really sure why.
OoDeLally
  • 201
