I'm using ubuntu 14.04 ubuntu 64bit and I'm looking for a slow motion software package like slowmoVideo http://www.webupd8.org/2014/02/create-classy-slow-motion-videos-in.html I tried installing slowmoVideo but it doesn't have an installable version for 14.04 ubuntu. Are there any other software packages that can do the same thing.
My goal is to take 1080p video of moving water and slow it down and play it smoothly so I can see how it flows.
Note the PPA does not work for Ubuntu 14.04 64bit this is the error
Failed to fetch W: http://ppa.launchpad.net/brousselle/slowmovideo/ubuntu/dists/trusty/main/binary-amd64/Packages 404 Not Found
W: Failed to fetch http://ppa.launchpad.net/brousselle/slowmovideo/ubuntu/dists/trusty/main/binary-i386/Packages 404 Not Found
Rick T
  • 2,303
It's a command line tool, but ffmpeg can do slow motion. If you don't have ffmpeg installed you will probably have to compile it from source (as far as I know there is not a ppa), but it's not difficult to do and it is worth it because ffmpeg is an excellent tool.
In terminal, you'd cd to the directory with your video that you want to slow down and use the following command:
ffmpeg -i input.mp4 -vf “setpts=(1/<speed>)*PTS” output.mp4
here's a brief explanation of the options and variables:
-i input.mp4 sets the input video. Note that the format doesn't have to be mp4 and the video can be named anything.
-vf sets the verbosity and forces the format of video.
"setpts=(1/<speed>)*PTS" will modify a piece of the video metadata, the presentation time stanp (PTS), to whatever you tell it to be, relative to the current PTS. The <speed> part should be replaced with how much you want it slowed down (e.g. '0.1 would slow it down to one-tenth speed; 0.5 would slow it to half speed, etc.).
Specify a different output.mp4 if you don't want to overwrite the original.
I wish I could say I came up with this myself, but it mostly comes from this blog post.
dagrha
  • 992
The homepage for slomovideo is HERE and the download page to just grab a deb is HERE
I'm not on my home ubuntu machine right now, but when I try to install the deb, it will not. -Might try to compile or run in a 11.10 vm.
Update:
I got it to install by doing the following..
Next I add the 2 lines to the end of /etc/apt/sources.list like so
sudo nano /etc/apt/sources.list
deb http://us.archive.ubuntu.com/ubuntu/ precise main restricted
deb http://us.archive.ubuntu.com/ubuntu/ precise universe
Add the ppa from the command line like so..
sudo add-apt-repository -y ppa:brousselle/slowmovideo
Then I edit the issue the command sudo nano sudo nano /etc/apt/sources.list.d/brousselle-slowmovideo-trusty.list and edit the two deb lines to have precise instead of whatever was there.
 sudo apt-get update
 sudo apt-get install slowmovideo
Scott Goodgame
  • 2,646
  • 16
  • 20
