I'm planning to upgrade to Ubuntu from Windows7
What should I expect with the following specifications?
4th Generation Intel® Core™ i7 4700MQ Processor 2.4GHz
8x3 GB memory DDR3 1.35v
Mobile Intel® HM87 Express Chipset
Intel® HD Graphics 4600
NVIDIA® GeForce® GTX 765M GDDR5 2GB - optimus tech
128GB mSATA SSD + 1TB 2.5" 9.5mm HDD 5400rpm
I'm completely new to ubuntu and linux
Does Ubuntu automatically detect and install all the drivers?
Thanks in advance
Fabby
  • 35,017
It is more beneficial to dual boot Ubuntu with Windows for you now if you are willing to give Ubuntu a shot and in 95% of the cases no errors will pop up!
Be aware of the process as it may give some problems only in the first boot process, I suggest going through the following thread and print it or have an offline copy:
Lost Windows 7 in GRUB after installing Ubuntu 14.04
Mainly this is what you will need in case windows boot failed (mentioned in the previous link):
https://help.ubuntu.com/community/Boot-Repair
Some problems also may arise for your graphic cards management, at first it will detect the Intel chipset and work perfectly with it, if you found your self comfortable then no need for installing the nVidia chipset driver (depending on your work).
After being familiar with the environment you will see yourself depending on Ubuntu in every day-to-day tasks :)
Ash
