Let me start with a disclaimer: I have tried to fix my problem by reading similar questions & answers, but so far no luck. Not only that, but I think that by making some changes to resolvconf I have messed it up further. I need someone to take me by the hand and help me fix this issue, I would be immensely grateful!
The situation is this: I am living in a building where the internet is provided by the university's network. Recently, some upgrades where done to the network, after which all my connectivity issues arose.
My Windows desktop PC will connect properly when using the same connection, no issues there. MY 14.04 ubuntu laptop, however, shows a normal connection to my router (wired or wirelessly, both work) but I am then unable to browse to any webpage.
Symptoms: - Can ping IP addresses but not websites (DNS issues?) - I can ssh to a server that I know is based at the university, so on the same network, and through there, I can use firefox to browse.
In case those are helpful, I will post below the output of ifconfig, and the contents of /etc/resolv.conf, which I think needs to be completely reconfigured after my failed attempts.
ifconfig:
eth0 Link encap:Ethernet HWaddr b8:88:e3:84:1a:0e
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:16
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:12843 errors:0 dropped:0 overruns:0 frame:0
TX packets:12843 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:826185 (826.1 KB) TX bytes:826185 (826.1 KB)
wlan0 Link encap:Ethernet HWaddr 20:68:9d:74:97:54
inet addr:192.168.2.100 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::2268:9dff:fe74:9754/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:216847 errors:0 dropped:0 overruns:0 frame:0
TX packets:194916 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:40559273 (40.5 MB) TX bytes:25893877 (25.8 MB)
Content of /etc/resolv.conf:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 127.0.1.1
nameserver 8.8.8.8
nameserver 8.8.4.4
EDIT: nm-tool output:
NetworkManager Tool
State: connected (global)
- Device: eth0 -----------------------------------------------------------------
Type: Wired
Driver: alx
State: unavailable
Default: no
HW Address: B8:88:E3:84:1A:0E
Capabilities:
Carrier Detect: yes
Speed: 100 Mb/s
Wired Properties
Carrier: off
- Device: wlan0 [ICIDU] -------------------------------------------------------
Type: 802.11 WiFi
Driver: ath9k
State: connected
Default: yes
HW Address: 20:68:9D:74:97:54
Capabilities:
Speed: 1 Mb/s
Wireless Properties
WEP Encryption: yes
WPA Encryption: yes
WPA2 Encryption: yes
Wireless Access Points (* = current AP)
wifiwifi: Infra, C0:4A:00:84:6B:5C, Freq 2422 MHz, Rate 54 Mb/s, Strength 25 WPA2
Sitecom1E55CA: Infra, 64:D1:A3:1E:55:CA, Freq 2472 MHz, Rate 54 Mb/s, Strength 17 WPA2
VosHotSpot: Infra, 00:23:54:08:02:8A, Freq 2412 MHz, Rate 54 Mb/s, Strength 29 WEP
Pritty fly for a wifi: Infra, 08:60:6E:E2:93:50, Freq 2437 MHz, Rate 54 Mb/s, Strength 15 WPA2
@Home41596: Infra, 00:14:6C:9A:D4:5C, Freq 2437 MHz, Rate 54 Mb/s, Strength 14 WPA
Pauw2: Infra, 00:1C:10:2F:B3:3C, Freq 2462 MHz, Rate 54 Mb/s, Strength 7 WPA
belkin54g: Infra, 00:17:3F:46:FF:7A, Freq 2462 MHz, Rate 54 Mb/s, Strength 5 WPA
Sitecom057D42: Infra, 64:D1:A3:05:7D:42, Freq 2447 MHz, Rate 54 Mb/s, Strength 19 WPA2
Indigo Plateau: Infra, 00:0C:F6:55:BE:B8, Freq 2462 MHz, Rate 54 Mb/s, Strength 17 WPA
NZ: Infra, 48:F8:B3:28:C2:09, Freq 2462 MHz, Rate 54 Mb/s, Strength 5 WPA WPA2
MAX-PC_Network: Infra, 6C:FD:B9:53:CA:68, Freq 2427 MHz, Rate 54 Mb/s, Strength 10 WPA WPA2
*ICIDU: Infra, 80:1F:02:A4:9E:BC, Freq 2462 MHz, Rate 54 Mb/s, Strength 89 WPA2
Zadnuk: Infra, 00:01:E3:C3:C0:61, Freq 2437 MHz, Rate 54 Mb/s, Strength 15 WEP
Studententehuis: Infra, 98:FC:11:B1:AC:99, Freq 2462 MHz, Rate 54 Mb/s, Strength 7 WPA2
IPv4 Settings:
Address: 192.168.2.100
Prefix: 24 (255.255.255.0)
Gateway: 192.168.2.1
DNS: 192.168.2.1
Cheers, ArcM
