Trying to deploy a multi-node openstack Juno, on 14.04. Here is my charm config file:
nova-cloud-controller:
openstack-origin: cloud:trusty-juno
network-manager: "Neutron"
openstack-dashboard:
keystone:
glance:
cinder:
ext1-quantum-gateway:
ext2-quantum-gateway:
nova-compute:
On Juju gui, all nodes and relation lines are green; however, I cannot access Project->Access&Security page, under horizon. Looking at rabbitmq log files, it seems that all access, from various services, are denied:
# tail -f /var/log/rabbitmq/rabbit@rabbitmq1.log | grep access_refused -B2 -A3
{amqp_error,access_refused,
"AMQPLAIN login refused: user 'neutron' - invalid credentials",
'connection.start_ok'}}
closing AMQP connection <0.17775.0> (10.0.0.77:34733 -> 10.0.0.60:5672):
{handshake_error,starting,0,
closing AMQP connection <0.17778.0> (10.0.0.77:34734 -> 10.0.0.60:5672):
closing AMQP connection <0.17781.0> (10.0.0.77:34735 -> 10.0.0.60:5672):
closing AMQP connection <0.17784.0> (10.0.0.77:34736 -> 10.0.0.60:5672):
closing AMQP connection <0.17787.0> (10.0.0.75:54438 -> 10.0.0.60:5672):
closing AMQP connection <0.17790.0> (10.0.0.62:39103 -> 10.0.0.60:5672):
"AMQPLAIN login refused: user 'nova' - invalid credentials",
closing AMQP connection <0.17793.0> (10.0.0.62:39104 -> 10.0.0.60:5672):
closing AMQP connection <0.17796.0> (10.0.0.62:39105 -> 10.0.0.60:5672):
closing AMQP connection <0.17799.0> (10.0.0.75:54439 -> 10.0.0.60:5672):
closing AMQP connection <0.17803.0> (10.0.0.62:39106 -> 10.0.0.60:5672):
closing AMQP connection <0.17806.0> (10.0.0.62:39107 -> 10.0.0.60:5672):
closing AMQP connection <0.17809.0> (10.0.0.62:39108 -> 10.0.0.60:5672):
closing AMQP connection <0.17812.0> (10.0.0.62:39109 -> 10.0.0.60:5672):
closing AMQP connection <0.17815.0> (10.0.0.77:34737 -> 10.0.0.60:5672):
Looking under /etc/rabbitmq, I don't see any files! Removing and adding relations, per Juju didn't configure rabbitmq for openstack?, did not resolve the problem. Here are some typical diagnostics:
rabbitmqctl list_users
Listing users ...
cinder []
glance []
guest [administrator]
nagios-rabbitmq-server-0 []
neutron []
nova []
...done.
# rabbitmqctl list_permissions -p openstack
Listing permissions in vhost "openstack" ...
cinder .* .* .*
glance .* .* .*
neutron .* .* .*
nova .* .* .*
...done.
rabbitmqctl list_vhosts
Listing vhosts ...
openstack
...done.
Any thoughts?
Cheers,
Edit 1: Seems that cloud:trusty-juno charms are not compatible with rabbitmq charm. For cinder and nova-cloud-controller had to set notification_driver = rabbit. Furthermore, had to manually set password, in rabbitmq server, for nova, neutron, and cinder users. In all cases, had to restart relevant services, manually. (Note that in case of cinder and cloud-controller, juju overwrites notification_driver.) Unfortunately, still can't access Access&security page. Keystone is reporting the following:
(keystone.common.wsgi): 2014-11-24 23:51:42,238 WARNING Authorization failed. The request you have made requires authentication. from 10.0.0.62
(keystone.common.wsgi): 2014-11-24 23:51:42,251 WARNING Expecting to find username or userId in passwordCredentials - the server could not comply with the request since it is either malformed or otherwise incorrect. The client is assumed to be in error.
10.0.0.62 being nova-cloud-controller.
Edit 2: (vis-a-vis 1st response.)
# sudo rabbitmqctl cluster_status
Cluster status of node rabbit@rabbitmq1 ...
[{nodes,[{disc,[rabbit@rabbitmq1]}]},
{running_nodes,[rabbit@rabbitmq1]},
{partitions,[]}]
...done.
Looking forward to the next release.
