I've been trying to install Samba with this terminal prompt:
sudo apt-get install samba
This is the response I get:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an
impossible situation or if you are using the unstable distribution that some
required packages have not yet been created or been moved out of Incoming.
  samba : Depends: samba-common (= 2:4.1.6+dfsg-1ubuntu2) but 2:4.1.6+dfsg-1ubuntu2.14.04.2 is to be installed
  Depends: samba-common-bin (= 2:4.1.6+dfsg-1ubuntu2) but 2:4.1.6+dfsg-1ubuntu2.14.04.2 is to be installed
  Depends: samba-dsdb-modules but it is not going to be installed
  Depends: samba-libs (= 2:4.1.6+dfsg-1ubuntu2) but 2:4.1.6+dfsg-1ubuntu2.14.04.2 is to be installed
  Recommends: attr but it is not going to be installed
  Recommends: samba-vfs-modules but it is not going to be installed
Where do I go from here?
Fabby
  • 35,017
first you need to run
sudo apt-get update
then you can search for the available packages related to samba by typing
sudo apt-cache search samba | grep samba
also if the package was halfway installed you can fix the broken packages by using the following command
sudo apt-get -f install
Hope this helps. Good Luck.
